Question about Cell Phones
Speaker problems - Cell Phones
I can't get the speaker to work, it works sometimes but when you dial out you can get the speaker to work just fine ,but it want work if you push the speaker when someone is calling in and you lay phone down to talk the speaker don't light up. to let you know that it is on
Posted on Sep 14, 2010
  • Cell Phones Master
  • 17,130 Answers
Please open your front panel and remove off the rear board. get access to the speakers/ earpiece and see if there is any dirt or lose connection. clean and check, if the fault persists, change the earpiece for the solution hoping that there is no harware issues in the motherboard. Hope this solves. Good day
Posted on Jul 29, 2010
No bass in righthand speaker
First try swapping the cables and put the left speaker cables in the right hand amp output and the right speaker in he left output. If the problem stays in the right hand speaker and does not move to the left as I suspect should, then it is a problem with your speaker crossovers. You may have to open up the speaker and check the wiring and then crossover. If the problem changes and appears in the left hand speaker you have an amp problem.
Jun 08, 2014 | Mission M73 Main / Stereo Speaker
It is an old speaker (DM601 S2) but well cared for. Have clear sound in one speaker and static in the other.
It sounds like a ground problem with the speaker crossover circuit or the amplifier. Turn the amp off and disconnect one speaker and interchange it with the other using the same speaker wires. If the static speaker is now working interchange the speaker wires and try it again. Or if the same speaker still has static it is the speaker. If the static is on the same channel then you have a bad wire or if both channels work it was a bad connection. If the problem remains on the same channel change the speaker wires. If the problem switched to the other channel then it is a bad speaker wire or connection. If the same speaker has the same problem it is most likely the crossover circuit in the speaker which is used to filter frequencies of the audio signal by using capacitors and coils. If the static speaker is now working and the other speaker is now not working it is the amplifier. If the static problem is on all input devices I would trouble shoot the preamp section of the amplifier.
Jun 23, 2010 | B&W DM602 S2 Speaker
Logitech x-230 2.1 Speakers: My speakers power on but do not work i guess because of loose wiring ...how do i open the speakers and check the problem??
If the speakers are still under warranty its best not to open them. You will lose your warranty. If the speakers are still under warranty, take them back to where you bought the speakers and ask them to replace the product.
But to make sure the speakers are working, plugg the green audio jack into another source to see if its the speakers or your pc. helps to narrow down the problem to a single source (pc or speakers), turn the volume up and down to test them completly.
If the speakers work with a ipod or a similar device, it could be your computer that is the problem.
Hope this helped :)
Dec 14, 2009 | Logitech X-230 Computer Speakers
Noise coming from speaker with controls
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.since you havent used your speakers for a long time disconnect it and clean it with a cleaning solution.make sure the electrical contact(connection) is tight enough since loose connections will cause such sounds.hope your problem is tackled..have a nice day
May 22, 2009 | Logitech X-230 Computer Speakers
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
Stereo problems
sounds like a speaker problem, but it could be the stereo itself. it could have a damaged circuit board. the only way to find is to test the speakers/head unit.
Sep 26, 2008 | 2000 Toyota Corolla
Amplifier balance problem
reverse your cable if the problem go to right speaker you have a problem in your amp and needs to fix-if the problem still in your left speaker you will have a problem in left speaker itself(cables or speakers)-start with cable changing and then speakers,
Jul 21, 2008 | Audio Players & Recorders
I have a kenwwod AX-7 home theatre systems. the right side top speaker (tweeter) on one side does not work. i'm thinking there is a fualt with the amplifier on the right side.
If the only problem is the tweeter, and the woofer is still working, you do not have a problem in the amplifier. The problem is the speaker. The tweeter is blown or you have a problem in the cross over network in the speaker.
You can always switch the speakers and connect them to the opposite channel. You can do this very easy at the back of the receiver where the speaker wires are at. Put the left speaker wires on the right speaker and the right speaker wires on the left speaker. If the same speaker still has no tweeter you know that the speaker is the problem.
The only way this could be a problem in the amplifier is if you have two different sets of inputs for each speaker, one being the low end for the woofer and the other being the high end for the mid range and tweeter. That would mean you have two sets of speaker wires going to each speaker. Each set of speaker wires would have a positive wire and a negative wire for a total of 4 wires going to each speaker. I don't remember this system being set up that way, but I could be wrong.
I hope this was helpful, you should be able to get the speaker fixed at an authorized Kenwood repair center in your area for a reasonable price. As a guide, my shop only charges $25 for the labor plus the cost of the tweeter to replace a tweeter. Any other shop should be similar. Kenwood does sell replacement drivers for almost all of their speakers.
Jun 21, 2008 | Kenwood Audio Players & Recorders
Stereo speaker suddenly stopped giving sound
You will need to take the speaker apart and with an ohm meter or continuity tester, measure the resistance of the speaker right at the speaker to see if the speaker is open. if it is you have no choice then to replace the speaker. If the speaker measures a low resistance, measure the wires froom the speaker to the output wires or terminals. Some speaker manufacturers install small fuses inside their speakers. Good Luck
Mar 29, 2007 | AAD E-30 Main / Stereo Speaker
Crazy cycling noise
a quick test, change the speaker wires between the speakers, if the sound goes over to the other speaker the problem is in the amp. But if the problem stays with the same speaker tower the problem will be in one of the speakers in the tower. since you said you get no sub sound I suspect ithe problem is not the amp, but the sub speaker itself
Oct 26, 2006 | Polk Audio RT1000I Speaker
Cell Phones Logo
127 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
