I have videocon V-NA-811 fully automatic top loading washing machine whose gearbox need to be replaced as told by company trained repairer. Earlier reconditio0ned gearbox was replaced and lasted only 3 years. Whre can I get new company made/fitted gearbox
5 Suggested Answers
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
  • 12 Answers
SOURCE: whirlpool top loader washing machine needs clutch
also check drive block for the inner basket to make sure it is ok.drive block is under the agitator.remove agitator with 7/16 socket.
Posted on Mar 04, 2010
  • 298 Answers
SOURCE: dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Posted on Dec 08, 2010
e-Guru
  • 3917 Answers
SOURCE: My Videocon Fully automatic top
Hi
E9 means the water level sensor is defective or the pipe connected to it is faulty.Generally error E9 means a problem with your water pressure sensor. do you have water in the tub? Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 02, 2011
E5 error on Videocon washing machine how to solve
E 5 ERROR IN VIDEOCON TOP LOAD WASHING MACHINE DRAIN SYSTEM IS ALL READY CLEANED
Sep 22, 2017 | Washing Machines
My videocon fully automatic washing machine (45FDx) is 7 years old. It is continuously showing E2 error. I have called the company technician but not of much use. Can u help pleae?
This can be due to a error in the control panel, You can switch off, remove the front panel and check for moisture on the panel, if so use a dryer to ward off the moisture. Also check the connections on the board. If the fault reoccurs then you might need to replace the panel board.Make sure the door switch, inlet valve and drains are clean.
Feb 12, 2013 | Washing Machines
GE WWSE5200B Top Load Washer does not drain or spin
Jim, we have same problem with Simpson top loader washing machine.
Our repairer eventually diagnosed it as a problem with the electronics but it can't be fixed. So we have a 3 year old machine with good pump , motor, gearbox etc but need to buy new machine now. Yours might be similar problem. Don't buy a simpson. Sorry, this is just what we've been told.
Jenny
Dec 03, 2011 | GE WWSE5200B Top Load Washer
Videocon washing machine model V NA-811 fully automatic body is rusted i would like to have a new body . where can i get it please inform me
Hi I have a Videocon V NA 811, don't know where to put the detergent and what is that small compartment with a net for
Nov 20, 2011 | Washing Machines
My Videocon Fully automatic top load washing machine (Digi Dolphin Dlx 7 kg) gives E9 error and stop functioning
Hi
Aug 02, 2011 | Washing Machines
Dear sir, I bought top loading fully automatic
Dec 08, 2010 | Samsung Washing Machines
I have whirlpool fully automatic splash model washing machine.i was told the tub of the washing machine is need to be changed because all the liquid which surronds the tub got empty due to improper...
I would not take the tech's word for this. If this is a fairly new machine, I'd call the company's 800 service number and talk direct with them.
Sometimes the local repair outlets need a little prompting from the big company. They will be able to tell you if the parts are covered.
Jun 27, 2010 | Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Changing a belt on a kenmore washing machine
99% of kemore washers (anything after 1950)
dont have a belt. and
the back does not come off for repair, the front does, with the removal of 2 screws
If the washer does not agitate or spin the usual cause is a plastic & rubber coupling between the motor and gearbox. replacement gearbox couplings now have a metal hub to prevent further breakage.
If this matches the problem you are trying to fix, reply & I will step by step the replacement process, its 2 screws, 2 bolts, a hammer & dowel & some time, to fix
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Sep 28, 2007 | Washing Machines
Washing Machines Logo
282 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
