Question about Panasonic Lumix DMC-FZ8 Digital Camera
After "bootup" of my panasonic DMC-fz8 DSLR objects in viewfinder or LCD screen are blurry
    Brigadier General:
  • 11,967 Answers
First of all, your camera is not a DSLR...it's a point-and-shoot that looks similar to a DSLR. Your problem sounds like a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 29, 2010
EVF blurred
Try adjusting the diopter. There's a knob near the upper-right corner of the viewfinder. Turn the knob while looking at the viewfinder.
See the "Diopter adjustment" section on page 39 of the manual.
Jul 17, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
My Panasonic DMC-LZ8 screen is almost total darkness, even with the flash and everything! I just want to know how to reset the default settings!
hi there, you can simply choose MENU, then select RESET so you can clear all the settings to default menu
anyway, did you change the LCD brightness??
thanks
Jan 10, 2011 | Panasonic Lumix DMC-FZ8 Digital Camera
My Panasonic Lumix FZ8 has a problem with it's LCD Display. If I use the ViewFinder everything is OK,but when I turn ON the LCD,the camera turns OFF. What is the problem?
If the battery is low it will do this. It requires more battery to operate the lcd than the viewfinder. Also, check to see if the power save mode is on.
Aug 09, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Using instructions required
You can download the Panasonic Lumix DMC-FZ8 Manual ( Operating Instructions) here:
Panasonic Lumix DMC-FZ8 digital camera Operating Instrutions (10.7MB)
Have fun :)
Apr 18, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera LCD screen image shakes and flickers
Either the LCD has failed or the flexible printed circuit board (pcb) edge connector has become loose.
Either way you only have two choices: get it fixed professionally or learn to love the viewfinder.
Until recently this repair would always have been uneconomical, but many camera repairers can now sort this out fairly easily, even if a new LCD is required. The bad news is that I'm finding that all good camera repairers have turnaround times of around 4-6 weeks at the moment.in both Europe and North America partially due to work backlogs and partially due to waiting for spare parts. For this reason I've used a company in Malaysia whenever possible for the last few years and can highly recommend their work. it's only useful to you if you live in that part of the world or pass through Kuala Lumpur regularly : http://electronics.zibb.com/profile/camera+service+centre/my/wilayah+persekutuan/kuala+lumpur/50000/26338866
If you can't wait that long then sell your camera "as is" and buy a replacement. A used FZ-5 is cheaper as it has 5MP but is otherwise the same camera and it has a better image quality due to less image noise. Anything above 2 or 3MP is ideal for most people who never print above A4 size (definitely more than adequate for those who only ever view on a computer monitor) and 5MP gives sufficient extra detail to allow a reasonable amount of selective enlargement.
Many photographers (myself included) rarely use the rear LCD and prefer a viewfinder so the price you get for your 7MP version may almost pay for the less popular 5MP variant. The vast majority of consumers ignorantly think that more megapixels=better, so the lack of demand for models with a low megapixel count means there are real bargains to be had.
Jul 22, 2009 | Panasonic Lumix DMC-FZ8 Digital Camera
Looking for viewfinder is blurry (Panasonic Lumix DMC FZ28)
There's a small dial on the left side of the viewfinder (next to the flash button) that allows you to focus the viewfinder. I only found it because I had the same problem - must have knocked it out of focus by accident!
Apr 07, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
No image displayed in either viewfinder or lcd
Does the camera take pictures?
To have the camera repaired it will not be cheap. You can ask for an estimate before sending it in.
Or, why not upgrade to the FZ7 or FZ8, FZ18?
Jul 06, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic Lumix DMC-FZ8 Digital Camera Logo
56 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
