Question about Sony Ericsson Z610i Cellular Phone
Cant on My Z610i cant on. when i press de on button, red light appear. My battery is fully charged. Please help. Thanks.
  • kanasai1011 Apr 26, 2008
    i sent it for phone service. but there is no problem wid de software. how?
  • Neehar May 25, 2008
    hello sir
    i have sony z610i when i press the power button,only red light blinks 5 times but it don't get on. help me regarding this.
    thanks & regards
    Neehar Neeraj
    neehar_sharma@rediffmail.com
    +919829095353
Than u sould try changing the battery with a new one fully charged
Posted on Apr 27, 2008
  • 75 Answers
Your phone has a software problem u need to go on a cellphoneservice
Posted on Apr 24, 2008
What would make my ipad just light and i can't get anything on it?
Try restarting your iPad. To do this, simply press and hold the Sleep/Wake button until a red slider appears; then slide the slider. To turn back on, press and hold the Sleep/Wake button until the Apple logo appears.
If tip above does not work, try resetting your iPad. To do this, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.
If above tips do not work, the issue could be that the battery is fully depleted. Plug it into a wall outlet for a while and see if your battery holds a charge. Please note that it can take up to 20 minutes of charging before the iPad will start up.
Nov 17, 2015 | Apple iPad Mini
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
HD camera.flip style
Did you do the Setup when you first started it? by holding the red button and following prompts? (to set up Language, date etc.) - if not try that. if yes, have you tried recharging it? Mine takes about 7 or 8 hours to fully charge (the red light will come on then when fully charged that light goes out) - it appears you have Ultra HD like me, so you should also be able to try some regular AA batteries in place of your rechargeable just to try that. If it works then, it is your rechargeable battery pack - either no good or needs charge. also when plugged into USB that red light should come on on front of the camera and if you look at the screen it should show a battery icon with a lightning bolt over it, shows the battery -how much charged. after 6 or so hours, press your red button and look at the screen - it now should be showing a battery icon that should by now be mostly Green and almost fully charged.
While charging the unit, Flipshare software comes up on your computer, "X" out of that software, so your camera will charge faster. My camera was doing similar things but I've had it a long time, and regular batteries worked, So I ordered a new battery pack and it has been fine since. Good Luck!!!
here is link to "what to do if battery not charging"
Jun 04, 2013 | Cameras
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I don't know how to get rid of the speaker symbol in the center of the Itouch screen.
Turn the iPod Touch off and then back on again. Here's how: Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If this doesn't help, try to reset the iPod touch while it is connected to power. To reset, press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge the device until it is fully charged.
Apr 18, 2011 | Audio Players & Recorders
Hi i have a 8220 and red light is blinking on charging. I have checked very possible thing even the charger but cant get around pls help! thanks
Please don't worry this is caused because of various reasons.The lights explains what could be the problem
Orange and Yellow lights mean no defects in the mobile.Orange is phone battery is very low.Yellow is for boot up..
Red light means-You have power management problem.
You have to understand why it is being caused..
1)Due to dead battery.The phone will charge but you phone battery will not get charged it acts like it is getting charged.Behind the scene it cant store the charge.
2)Due to charger is not working properly no charge in the battery.
So you have replace this accordingly..
Please try this some time phone booting may be stopped,
This is not a solution when the battery is dead or fully down....
Sometimes The boot cycle of the phone is stopped.You have to start it.Remove the battery and place it again and press the red 'end' button continuously until the red light flashing stays on.Press green button' call' button and hold the red button...Now press these two buttons alternatively until you see hour glass symbol.Now when you see hour glass wait and see the phone booting....
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Wii remote
Try to resync your remote. To do this:
1) Locate the red button under the battery cover on your remote.
2) Locate the red button near the sd card port on your console.
3) Press both buttons within a couple seconds of each other.
4) Wait a few seconds if your remote doesn't sync, retry.
Good luck. Please rate, thanks.
Mar 03, 2010 | Nintendo Wii Remote Controller
On a vector jump start system, does the green light have to stay on to indicate that is charged> what if only the 2-3 red light go on when i press the test button?, when the green is flashing while...
2 - 3 red lights indicate not fully charged. Green light = fully charged.
Not fully charged does not mean it will not function. For best results, your device should be fully charged. If you have an emergency and are not fully charged, it will not hurt to try to help with a partial charged device IMHO
Thanks for posting at FixYa.com
Dec 13, 2009 | JUMP START SYSTEM
MY SAMSUNG R60 LAP TOP WONT WORK.. THE USER GUIDE IS INSTALLED IN THE COMPUTER SO I CANT ACCESS THAT! IT IS DISPLAYING A RED LIGHT WHICH I THINK MEANS THE BATTERY IS FULLY CHARGED??? BUT NOTHING HAPPENS...
my samsung laptop is green when charged, red when charging.
try turning it on with the power adaptor plugged in and the battery removed.
if this works, i assume your battery is damaged
Oct 01, 2008 | Computers & Internet
Sony Ericsson Z610i Cellular Phone Logo
69 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
