Question about Kenmore 43389 Electric Double Oven
I have a Kenmore Double Oven 911.41189994 ,get a FO fault code.It does reset for a while then it comes back.sometimes it will go weeks with out doing it,then it starts all oven again. The oven works fine.
  • 15,935 Answers
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
I have a Kenmore double oven model #911.41185992 and it is reading a code of "fo". There are times that it beeps when trying to set the temp in the oven. If I turn off the power from the electrical panel...
The "F0" fault code is indicating a shorted OFF key pad. A technician would determine if the problem is the Key panel or the Control board by disconnecting the ribbon connector and measuring the flat cable pins 13-14. It should be open and should measure between 100-150 ohms while pressing OFF key.
He would disconnect power to range before testing the key panel.
I recommend calling a service technician to diagnose and repair your range
Mar 05, 2018 | Kenmore Ovens
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
I have a Kenmore 30" double wall oven model no. 911-41185. It will not let me do anything and keeps displaying FO and beeping. Can you tell me what is wrong?
F0 means no error. press cancel to clear display.
If you cannot then that key might be stuck, just a guess. I have your tech repair manual with failure codes and troubleshooting on page 43. This NOT a user guide. It is meant for qualified peeps. So be careful. Late model double oven tech repair manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 06, 2010 | Ovens
Kenmore double oven keeps beeping and shows error code FO
Hello there:
F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Dec 31, 2009 | Ovens
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Kenmore 43389 Electric Double Oven Logo
114 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
