Question about Gadzoox Networks Capellix 3000HA (CAPELLIX-3000HA)
I have an old Gadzoox Networks Capellix 2000 FC Switch and don't know the password to the default login "user". Is anyone able to assist in resetting the password back to default?
I forgot my Dell Dimension E310 administrator password and can't log in. What should I do? Should I call Dell to reset the password or switch the administrator to another user?
That would be the best solution. As long as you can login and the account has administrator rights.
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 07, 2012 | Dell Dimension E310 PC Desktop
How to change password on my router
If you don't know the password to the router you can hold the reset button (small hole on back) for 10-15 seconds to reset to factory defaults. Login using admin admin for user and pass, or blank for pw.
Sep 25, 2012 | D-Link Wireless N 150 Home Router 4Port...
Hi all i hv configured dlink switch DES 3350sr with user name and password. i saved. but now problem is that when i reboot this i can not login with that user name and password. so after all problem is...
evidently your sign in name and password were not saved. If you remember the old password and name try that. IF not, thenn find the reset switch, press it and start fresh with factory defaults
Mar 16, 2011 | D-Link (DES-3350SR) (851210) Networking...
Hello can u help me with the default user and password for an ASSUS router? i lost the old user manual and i reset it to default and i forgot the default user and password to set it. thx
Connect youra router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 04, 2010 | Gateway Computers & Internet
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
Aug 03, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
How to recover forgotten admin password for windows xp ?
Option 1: If the user you have is an administrator account, go to the control panel and select user accounts. When you are in user accounts, find the account you want to remove the password from and you will see the option there.
Option 2: If your user is NOT administrative, you can use ERD commander to reset it. You basically burn ERD onto a CD and it will boot when you restart. There is a program called Locksmith that will remove or change the password for you.
Jul 19, 2009 | Microsoft Windows XP Professional With...
I forgot my password
Find and depress the reset button on the bottom/back of the unit to hard-reset the router to factory defaults. Note: this will lose all user configured options but will set the login for the router back to defaults. Check your owners manual for the default login and configuration options.
From what I have been able to research on this router, the username and password for this router may be:
USERNAME: sysadmin
PASSWORD: nortel
But this information is unconfirmed.
Mar 04, 2009 | Nortel Networks BSGX4e Business Services...
Slingshot Admin password removal/reset and User's manual
Most of the switches/hubs have a reset button in front or on back. If there is no reset button, then more then likely you will need a crossover cable, you can probaly get one at compusa or radio shack. With the power off to the Switch, and all cables disconnected, plug one end of the cross over cable into WAN port 1, and plug the other end into LAN port 1. Power on, and wait for the front lights to cycle through. After about 3 minutes, power off, power on, wait 2 minutes, power off, plug in all normal cables and power on. This should take it back to factory default, and you shoudl be able to log into it from the web browser of a PC plugged into it. Most default ip addresses are either 192.168.0.1 or 192.168.1.1
Dec 21, 2006 | Gadzoox Networks Slingshot 4218 Networking...
Gadzoox Networks Capellix 3000HA (CAPELLIX-3000HA) Logo
49 people viewed this question
Top Gadzoox Networks Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Gadzoox Networks Computer and Internet Expert? Answer questions, earn points and help others
