Question about Asko W6021 Front Load Washer
Asko W6431 Quattro front loader
Am getting an F3 message. Have opened the little door at the bottom of the machine and removed two hairclips and two $1 coins (yep, teenager). Then I put it on to wash again and got the F3 message again. I checked the filter again, but there was nothing there.
  • frustr8edCR Apr 28, 2008
    Had the same F3 problem after only 8 washes, checked filter, but nothing wrong. Asko response is we use too much washing powder, so the repeated F3 error is our own fault. Funny thing is, we use bugger all powder...
    Champion:
  • 207 Answers
Unplug the machine. Remove the filter, take a flashlight and get your head down to check if something has fallen deeper in filter and pump housing which block the pump turbine. Also, make sure to check if the outlet hose isn't clogged or jammed with something too.
Posted on Apr 24, 2008
F3 Error Message
F3 is a pump problem check the pump trap and clean it this should clear it up...
Aug 25, 2007 | Asko W6441 Front Load Washer
How can I open the door on hoover Quattro washing machine.
if its a front loader remove lid and plug u can get the door open from top with a long screw driver and a bit of patiace
Mar 01, 2015 | Hoover Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
I have an f3 and f4 error code on asko washing machine front loader. i know what the error codes are just dont know where they are anyone can help I need it thanks
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Feb 14, 2011 | Asko W6441 Front Load Washer
I have an asko quattro front loader washing machine it wont spin out properly leaving my clothes wringing wet can you help?
Hi, Welcome to FixYa. Have you checked the pump to insure the filter isn't clogged, or do you know where it is and how to check it ? If its clogged it won't allow the clothes to spin out enough due to water extraction being prevented. The insert/filter is located on most Asko washer below the main basket door behind a toe panel or square access door. Once found, turn it counter-clockwise to remove it and clean inside thoroughly. Let me know how you do or if you don't understand or even needing more assistance. Thanks for choosing Fixya and good luck. Regards, Macmarkus :)
Nov 01, 2010 | Asko Washing Machines
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
I have an asko wm200 washing machine. I have an F3 error, which is stopping me from opening the washer. The washer is also still full of water. Just need to know how to get the door to open and the water...
open the little door at the bottom or remove the toe panel... then there is a coin trap... that will let you remove the water there is a black hose with a plug on the end remove plug and drain the water...by turning it and pulling it you can remove the coin trap and you my be able to remove somthing stuck in it... also there is a red string you can pull it and release the door
Hope it helps if NOT let me know more about your problem... and I will help
Jul 08, 2009 | Asko W6761 Front Load Washer
Not only is my asko washing machine leaking, the code "F3" flashes continuously, and my clothes are locked inside. What does "F3" mean? and how do I get the door to unlock?
F3 is a blocked drain...open coin trap remove blockage... also in the trap door is a red release string.. remove screw and pull it will release the door...
Jun 30, 2009 | Asko W6441 Front Load Washer
Asko W6021 Front Load Washer Logo
566 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
