Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I cannot Fax in and out...error 49 turn off and on. After i turn on the printer another error show that "power failed to recover Fax setting restore"....please Help~
    Sniper:
  • 56 Answers
Try the following: got to the menu (the wrench) and with the arrows look for service, press ok and look for restore defaults. After that unplug the fax line (this is very important). Go to the hp website and download the firmware update and run it (while updating dont to anything to the printer, no print, copy, fax.) when that is completed try to fax again this should resolve it.
Posted on Sep 08, 2010
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
Stampante nf 1522 errore 49 non invia e non riceve fax grazie
49 error is an internal embedded software error.
1) turn off power and wait about 30 seconds, power on and if error comes back, see step 2
2) www.hp.com/support/ljm1522
Jan 14, 2011 | HP LaserJet M1522nf Multifunction Printer...
When I tried to fax the doc.s always the error 49 is showing up and automatically turned off. And it is saying memory is full... what should I do???
Hi, Please try the below steps to resolve error 49: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=lamerica_nsc_carib&taskId=110&prodSeriesId=3442750&prodTypeId=18972&prodSeriesId=3442750&objectID=c01558499 Also woudl like to tell you that the memory errror is caussed when a print cartridge has a missing e-label. Reinstall the print cartridge.Turn off and then turn on the product.If the problem is not solved, replace the cartridge
Mar 25, 2010 | HP LaserJet M1522nf Multifunction Printer...
What is the meaning of eror 232*
Error Code: 232
  • A communication failure occurred between the two machines.
  • The user at the remote machine might have pressed the Stop key.
  • The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
  • The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
  • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM .
  • Set the host machine to receive at a slower transmission speed.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
Nov 04, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Recommended action 49 and 79 Errors, Turn off then on The product has experienced an internal embedded software error. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If you have recently installed a memory DIMM in the product, turn off the product, remove the memory DIMM, reinstall the DIMM to verify that it is seated properly, and then turn on the product.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Jul 02, 2009 | HP Laserjet M2727nf Multifunction Printer
Cannot send fax
plz chek telephone line or fax roulers
Jul 01, 2009 | HP Photosmart C7180 All-In-One InkJet...
Error message 49,ff81
it is temporary printing error, turn off the machine and wait 10 sec and turn it on again it should clear.
Oct 15, 2008 | Office Equipment & Supplies
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
442 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
