Question about Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
Dell inspiron 1525 laptop dvd not working - Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
  • Dell Master
  • 3,530 Answers
Hi. Please check first if computer was able to detect the DVD drive in computer 's device manager. Go to control panel then click system then click on device manager. if computer wasn able to detect the DVD ROM inside the device manager then follow the procedure below.
  1. Click Start , and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Jul 29, 2010
  • Dallas1965 Aug 28, 2011
    This was the perfect solution with no fuss! drive is back working...Thanks guy!
  • Dell Master
  • 17,130 Answers
Trty to open the tray and clean the laser eye ( optical unit) with a clean swab , with very gentle brushes to clean the lens. try to see if the cd works, or spins or tries to read. if there is no signs of any action it is possible that you have an hardware problem. The last that can be done is to reinstall the DVD drivers into the system once again. If this wont solve I am afraid that you will need to check your motherboard for hardware issues that can be expensive too.
Hope you try. Good day
3 Suggested Answers
  • 97 Answers
SOURCE: dell inspiron 1525 cd drive not recognizeing
ok what you do is go to control panel and system and then click ur driver and then install the dvd one
Posted on Aug 03, 2009
anandsharad
  • 137 Answers
SOURCE: i have a dell inspiron 1525 laptop and my cd/dvd
The CD, CD-RW, DVD, DVD-RW, Blu-Ray and any other drive that uses a laser to read data from a CD. In general, most optical drive problems can be resolved by:
  • Updating the optical drive firmware
  • Updating the burning software
  • Updating the DVD playback software
  • Updating the computer's video driver in cases of video playback issues
  • Updating the computer's audio driver in cases of audio playback issues
To download the Firmware of your machine click here. i have selected the default 1525 but if you click on enter the service tag, it will give you your computer's firmware. or you can check it in device manager as well.
you can also try deleting the upper and lower filters. in regedit.
in vista. click on start /type regedit in start search.
then continue the action and then click on the +HKEY_LOCAL_MACHINE / + SYSTEM / +CURRENT CONTROLSET / +CONTROL /+ CLASS /+ {4D36E965-E325-11CE-BFC1-08002BE10318} and on the right side look for upper filters or lower filters and delete them. and then restart the computer. it should fix this.
in case the issue is not resolved. you might need to get the optical drive replaced.
if this information was helpful. please rate the solution.
Posted on Sep 25, 2009
Inspiron 1525 PC Notebook: can i use Dell Inspiron 1525 to burn dvds? How to ...
Hi Richard, yes you can burn DVDs with your laptop. Check the CD/DVD disc that came with your computer. However, I understand its pre-installed either with Roxio or Sonic utilities. On the other hand, if you have Vista and Windows 7 it will do as well.
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
May 18, 2010 | Dell Inspiron 1525 Notebook
Booting with External DVD for Dell Inspiron 1525
Power on your system, Press F2 on Dell logo. This would take you to system BIOS. Ensure that USB controller is ON, and USB emulation is also set to ON. Save settings and Exit. System would reboot now. Press F12 on Dell logo, and select USB ROM as the boot device. This should boot your computer through your External drive. If it still doesnt work, try switching to a different USB port. If none of these steps work, it may be a problem with the boot sector on your External drive.
Good Luck!
Abhishek
Mar 22, 2010 | Dell Inspiron 1525 Laptop Jet Black
I have a problem with the dvd disk drive on a dell inspiron 1525
Always be sure to close any open programs you do not need to run at that particular time. Also, close your internet connection. The reason for this is to allow the maximum amount of memory to be used by your media software.. Try this. It should work, ok? GOOD LUCK!! Lucky4lynn2
Feb 23, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
My cd/dvd drive won't read data cd-dell inspiron 1525.
99% of the time it is a failed laser. Time to replace that drive, especially when you know the disc works in other machines.
Oct 26, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell 1525 can read CD but does not read DVD
Hi, If your Dell 1525 has got a CDROM drive or CD Burner/Writer then you can only Read and Write the CD's
But if you got a DVD optical Drive then you can Read CD and DVD too...
If you need more clarifications on the same, pls send me the Service Tag of your computer. ( you can find it underneath the laptop)
Jan 22, 2009 | Dell Inspiron 1525 Notebook
Poor DVD drive audio Dell Inspiron
I also have an inspiron 1525 and I once had this issue (I'm running xp pro) but I found that you need to reinstall you audio driver, here is a link to the vista driver
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_PM_1525&os=WLH&osl=en&catid=&impid=
Dec 12, 2008 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner Logo
535 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
