It says door locked even though I can open and close the door. The machine won't work this way.
    Problem Solver:
  • 6 Answers
The door interlock unit, just behind the front outer panel, can go faulty and will need replacing. On some models, you will have to pull off the door gasket on the side where this is located, to get in and replace it.
Occasionally, you can access these from the top, with the top panel removed. If you are really lucky, as few come out from the front after removing a couple of screws. A few machines have the front panel removable, but this is rare. CAUTIONS: 1) ALWAYS UNPLUG MACHINE BEFORE DOING ANY WORK 2) some interlocks have an thin plastic air pressure pipe attached to the bottom, so ensure you locate this pipe, don't let it fall out of the way, so you can gat at it to push it on to the new interlock during re-assembly.TD
Posted on Jul 29, 2010
Fob not will not open or lock even though its working
How do you know it is working?? if it wont open or close the doors, it might just be a flat battery in the remote. Try changing the battery first.
May 02, 2016 | 2000 Rover 75
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
1997 ford explorer rear door child locks won't let doors open from inside even though locks are in ullock position
I have the same problem Shari did u find out the solution email pj121368@hotmail.com
Feb 11, 2013 | 1997 Ford Explorer AWD
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi! My LG washing machine is showing a "de" error code. It won't allow water into the drum. Please help
Hi, the error code "dE" signifies a door open error. This may simply be because the door is not all the way closed. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it, though it could also represent a number of other problems. There may be a faulty door switch, a malfunctioning electrical connection or a damaged gasket.
Jun 24, 2011 | Kitchen Ranges
Display shows flashing 'door' warning,even though door is closed.....then when door is opened/closed a couple of times display will dissapear and re-appear every 3 seconds or so. Help!
The symbol indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 09, 2011 | Washing Machines
Light comes on for open door even though door is closed properly
almost certain door latch contacts are not making proper contact when door is closed. Give a firm close which might rectify it. Otherwise suggest latch replacement.
Sep 19, 2009 | Washing Machines
I have a hotpoint few12 washing machine and have just replaced the interlock door lock as door locked indicator kept flashing even though door was closed,sometimes happened mid cycle,and had to open...
hi
check the spring on the door handle/catch,the easiest way to check this if you close the door and it indicates that the door hasnt locked,push the inner part of the handle towards the machine,if it locks then the spring is worn.(this is more commen than the interlock).
Aug 03, 2009 | Washing Machines
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Washing Machine LG WD-8013F
it may be the lock but this model is known for board faults,take of the top panel and remove the control panel and see if the board is burnt.there was a recall on some of these machines a while ago in australia not sure where you live
Apr 03, 2008 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
