Question about HP Pavilion F1703 17" LCD Monitor
HP PAVILLION F1703 GOES A SLEEP AND CANT TURN ON WITH OUT RESTART
F1703 GOES A SLEEP
July 2010
I have 3x F1703 screens, which Ive had in store, due to the problems of powering up the panels. Basically as descibed here, panels would go out.
After reading this posting, I decided to strip the 3x Panels down, as I was going to dump them anyway, in the past fear of attempting to open the cases and breaking meant I never got around to attempting to fix.
The front face comes off with a bit of difficulty, via prizing open using a kitchen knife,,, with 3 panels I had practise, so do take car. Work from the bottom edge of your panel.
On opening, you have a secure backplate you have to remove by unscrewing 12 screws, this then allows you to flip over the panel and to get to the control boards.
My first screen was damaged, but this had a later Processor board but an earlier power amp board...I salvaged the amp board with torodial coils. then used this on the 2nd panel - this now works fine!
The 3rd Panel, is also a early 2003 model, but again has a slighly different amp board, Im going to have to canablise the boards from 2 panels to make one good one.
The POWER fault was FOUND TO BE none other than a loose soldering on the power connector to the amp board, the solder was cracked and only needs to be soldered!
thats todays job, re-solder the amp board power socket and hopefull 2 out of 3 panels will be working once more
Hope this has helped
Thanks for the article as its enabled me to fix 2 panels, with thanks to you all
Clive - in the UK
Posted on Jul 29, 2010
Computer will not wake up from sleep mode
- your comp is in hibernation mode
- go to control panel>>power management>>put to NEVER the sleep mode,hibernation,HDD,battery
- restart system
Mar 25, 2010 | HP Pavilion dv2000t Notebook
I just changed my tower and now my hp pavilion is going to sleep
I assume you have already try with other PC with the same result. You may have bad solder joints on the four inductors in the inverter circuits. Service manual: http://www.eserviceinfo.com/downloadsm/40333/HP_F1703.html
Tips: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
Mar 19, 2010 | HP Pavilion F1703 17" LCD Monitor
NO LIGHT ON POWER BUTTON ON HP PAVILLION f1703 DISPLAY MONITOR
knpeterso548, I wouldn't even worry about that little power "ON" indicator light. As long as the button functions as an "on" or "off" switch, you will only need to remember to turn sleep mode setting to total "off" mode (disable) in the pc. This way you will need to turn off the monitor with the BUTTON when you will be away from the pc for more than 1-2 hours. Face IT!!! Even I would charge you $15 just to open it up! $10 for a new "on/off" switch/with led and then $10 to put it all back together again. Give a call to HP (High Price) and find out what they will charge for replacing a switch. As long as the LCD panel displays brite, crisp images and text, you are way better off than those who don't see a thing on their LCD screen when they press the power "ON" button.
Bye for now. 12fix louie
Nov 05, 2009 | HP Pavilion F1703 17" LCD Monitor
As soon as i turn on my computer the monitor goes into sleep mode
try another cable I have tis problem on mine & I have to do them up solid, also check for bent pins in the cable & bend the back carefully & unplugged.If not you may need to set up the computer to output, try another monitor to rule that out.
Hope this helps!
Sep 22, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor screen is black when hooked up to my laptop.
u have to set screen resolution of monitor to 1024 *768
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
