Question about Dryers
I have Kenmore 70 series dryer (Model: 110.68712894) that is currently not working. If I press the start button, the drum does not turn and I don't believe it gets hot. I can hear the timer ticking when the dryer is on the timed setting. I can also hear a slight (very low) crackling or humming. I have taken the lid off and the belt seems fine.
  • llanning Aug 03, 2010
    That was great Phil. Thank you!
    President:
  • 949 Answers
Since you can hear a noise from the timer that eliminates a lot of items.
The most likely suspect that has gone bad is a thermal fuse (see image below with part number).
This is located on the back just to the left of the vent opening. Unplug the dryer and take the vent pipe off. Remove the back cover and you will see this device with 2 blue wires attached. You can use an ohm meter to test the part, it should read 0 ohms or closed. You can also carefully jump across it to see if the dryer will start with it bypassed.
If this part is okay then the next likely suspect is the start switch itself. You can test it the same way, hold the switch down and take an ohm reading or carefully jump it to test.
The last part and least likely is the motor itself. If this is bad you are at the point where I would invest in a new dryer. But the motor can be replaced if you wish.
Posted on Jul 29, 2010
    Thanks Phil! That was exactly the issue. I was able to jump across the fuse and the dryer worked. I have orderd the part. Another individual, who happens to work on appliances, told my wife that when the thermal fuse goes it is best to replace the other fuse because it will often go out within a couple weeks of the thermal fuse. Do you have any idea what "fuse" this other person might be talking about? Does that make any sense?
  • Philip Aug 03, 2010
    The other 'fuses' they are talking about would be the Cut Off fuse, Hi Limit thermostat and operating thermostat.
    The rule of thumb is the cut off and high limit go together.
    The thermal fuse and the operating thermostat go together.
    It is good to look over and clean what you can while back there as air flow can be a leading cause of these thermal (heat related) devices to go. If you are to replace another part with the thermal fuse the only one that would be necessary would be the operating thermostat, that is the one right next to the thermal fuse, the part number should be on it.
    I hope this helps!
    Phil
My Kenmore 70 Series Extra Capacity dryer wont start
there is several problems it could be the bearings in drum could be bad or there could be a sock or other item locking up drum from turning.
Nov 06, 2013 | Dryers
Kenmore dryer 70 series drum not turning
http://www.youtube.com/watch?feature=player_embedded&v=bJ5TNlzHKhA
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 06, 2012 | Kenmore Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
May 05, 2009 | Kenmore Dryers
Drum wont turn
Is your motor working? How about your belt? Is it broken?
Jan 24, 2009 | Dryers
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
212 people viewed this question
Top Dryers Experts
Marvin
Marvin
