Error 10 laser unit failure on phaser 7700GX - Office Equipment & Supplies
  • 2,072 Answers
That requires the replacement of either the ROS ( laser) assembly or the MCU board. I have seen both cause that code and indicate the laser has failed.
ROS is the laser assembly.
MCU board may not be detecting the ROS.
It is possible the connector that runs from the ROS to the board is loose, you may want to disconnect and reconnect that.
If the ROS is bad, you also have to have a laptop to connect to the machine to align the colors. That is called the regicon adjustment.
Posted on Apr 25, 2008
Xerox phaser 6360 laser failure code 10
You may have to replace the laser unit. Code 10 is a warmup failure. You need to reseat the connector to the ROS Harness first. If the issue persists, replace the laser unit. Issue persists, check continuity between pins J15 and J151. If there is continuity, replace the Engine Control Board, if not, replace the ROS Harness
Feb 03, 2014 | Office Equipment & Supplies
Xerox phaser 6360 laser failure code 07
The most likely cause here is the laser unit, check all connections to the laser unit and cycle the power (turn the machine off and on) if error continues replace the laser unit. You can buy a replacement for $350 new or $225 refurb. Part# 062K17233. Installation isn't very simple, so if you aren't a technician you may want to bring it to one. Good luck
Apr 22, 2011 | Xerox Phaser 6360 Laser Printer
11 error
You have not provided a lot of information here....
But my best guess is that you have a Laser Scanner motor failure...
If the error repeats 3 times in a row, the device will lock out, and need resetting by a technician.
Safety note
- If you are not competent at fixing electronic equipment, you should get a qualified technician to fix this
Check the cables to the Laser Scanner and reseat them.
P401 and P402 on the engine controller PCB
Dec 21, 2009 | Xerox Tektronix Phaser 7700GX Laser...
Error 11, laser unit polygon motor failure. If this fault reoccurs 3 times successively the 7700 . enter diagnostics and clear tech rep fault and clear this 09-380, 09-383.
Oct 26, 2009 | Xerox Phaser 7700 Laser Printer
Phaser 7700GX getting yellow bar down the side of page on all prints
Try cleaning the Laser Unit for Yellow. Try replacing the Imaging Unit for Yellow, or simply take it out and move it to another color.... if the problem occurs on the the other color then it is definitely your Imaging Unit. One of those two is probably causing your issue.
Good Luck.
Sep 10, 2009 | Xerox Tektronix Phaser 7700GX Laser...
Printer error - call for service, 9-911 what does this mean?
It will be best to run diagnostic tests on the printer and especially the electronics before coming to any conclusions. My first guess would be that some part of the memory went south. The test procedures are in the service manual which can be downloaded at:
Apr 16, 2009 | Xerox Tektronix Phaser 7700GX Laser...
Xerox Phaser 7750
There is a motor in the laser called the polyogon motor, It turns the mirrors in the laser.
It most likely is not starting fast enough.The laser isnt that hard to remove. But if it has failed, it is pretty expensive.
Let me know if you want to attempt to pull it.
Sep 10, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7700GX...Error 10, Laser unit failure. How can it be fixed?
that requires the replacement of the ROS ( laser assembly) and some color alignment adjustments.
Apr 24, 2008 | Office Equipment & Supplies
Xerox Phaser 7700GX error 10 laser unit failure....How can be solved?
Check the left side door assy where the fuser is located, on the door near teh top towards the rear of teh printer there should be a piece that sticks out which will close a interlock swith when closed. It may be black or same color as teh covers. If this is broken off it will cause the problem you describe. Easy way to check is to use a screwdriver to push in on the interlock to close it and see if the problem goes away.
875 people viewed this question
