Question about IBM ThinkCentre A50p PC Desktop
How to format ibm think center desktop computerwhile i am trying to format the setup cannot access the hard disk error arrives
  • 61 Answers
SOURCE: Hard Disk failure
Try to run CHKDSK from command prompt, and if that doesnt work, its probably corrupt / hard to recover
Posted on Apr 21, 2009
  • 19 Answers
SOURCE: i have problem with my ibm think center.my sound
is it an integrated audio device or a sound card? i own a thinkcentre and i had the same problem, but just going into the device manager and right clicking on the problem device and updating the driver solved it for me, but i also added a soundblaster audigy ls sound card and both work fine now, however i have the same problem on my other pc, a dell, and i cant solve that one. another reason on my list of many to not buy a dell.
Posted on May 11, 2009
SOURCE: IBM Desktop no sound after i tried to connect it to Television
hi Appesh i have ibm think center p4 , there is no sound driver in my
ibm where can i get sound driver. i have downloaded many ac 97 drivers nothing works..
help me plz
Posted on Jan 11, 2010
  • 388 Answers
SOURCE: i want to format my IBM thik center but in setup
try looking for the cd name it my be somthing like (CD-HITACHI-DVD ) or simlar
Posted on Oct 06, 2010
SOURCE: error 0194 ibm think centre 8185 desktop
Try going into the Bios or System Setup and see if there are some settings for System Security or Asset ID Antenna. It sounds like something is set in the Bios. Turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup. Hit the key when you see the message or it will not work and you will have to reboot and try again.
Posted on May 30, 2012
I just bought a Dell Back-up plus 1 TB hard disk . when i plug in the USB cable it does not show up on My computer but it shows on "Device manager" and "computer management" .. so i cannot use it as a...
The only thing that I can think of is that you need to go into computer management and click on the "disk management" sub-heading under storage. From there all of the hard drives in the computer should show up. Find the new hard drive in the list and right click on the part where is say Disk 1 or Disk 2 or which ever disk is the correct one (it should be around 930gb or so). Then select initialize disk, and follow the wizard through the choices to setup the disk as a basic hard drive. After the disk is initialized you need to format it and then you should be access the drive in my computer.
Austin
www.we-supply.com
Aug 08, 2013 | Computers & Internet
Have IBM THINKPAD 380XD Laptop, windows 98 is not openning, asking for registry rpair, SCANREG is not possible, format C is not possible. Needs hard disk replacement?Where can I get this hard disk drive or...
for registry error i don't think its required for replace the hard disk ... boot the laptop through win98 boot able cd and delete the all partition using fdisk command and try to install the os .............
Dec 14, 2009 | IBM ThinkPad T30 2366 Notebook
My IBM Thinkpad R40 laptop stopped working.The IBM Think Pad screen comes up and then with a beep,the system shuts down.Went to a support shop and found some IC on the system board was damaged.Now,for data...
Unless the hard disk itself is damaged, data should be perfectly recoverable. This does not mean that any USB device will be able to read the unit. Some external attachments I found were not capable of reading large disks, or required those disks to be formatted while in the attachment, meaning that the disk addressing mode wasn't autodetected at all.
On the other hand, the disk MIGHT be damaged. Sorry to mention it but it's a possibility. Were those damaged IC on the board connected to the disk I/O system? (Or, maybe, the ICs only seemed to be damaged, but were actually working - it was the HD which was damaged all the time, and the system rebooted as soon as it tried to access the disk).
I'd suggest having the disk connected with a 2.5"-to-3.5" adapter to a Linux machine as secondary hard disk. This will allow direct talk to the disk unit, bypassing external devices and the like, and allowing direct access to the partition, with a much more informative error logging than Windows systems are generally equipped with.
Nov 03, 2009 | IBM ThinkPad R40 2897 Notebook
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
My laptop does not recognize the hard disk after formatting;
Actually, have you tried running the Windows install yet? When you're in Windows Setup, it should recognize the hard drive as a device, even if it's not formatted or formatted properly.
Try going into the BIOS for the laptop (it might be called Setup Menu or some such - you should see a prompt for hitting a key like Del to get there) and look and see if the BIOS recognizes the hard drive. If the BIOS doesn't see the hard drive, then the problem might be with the laptop and not the hard drive.
Dec 29, 2008 | IBM ThinkPad R31 2656 Notebook
Error to Detect, hardisk must be formatted
The problem might not be with the HHD instead it could be your bios setup. you will have to download drivers for the bios of you laptop and install them in your operating system then try to access the hard-disk.
Mar 12, 2008 | Computers & Internet
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
IBM ThinkCentre A50p PC Desktop Logo
545 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
