Question about Creative Labs Gigaworks S750 Computer Speakers
No lights, no response after power outage
I went away on vacation, while I was away there was some maintenance work being done on my building. They cut the power to part of the building, which turned off my computer and basically all my electronics. My speakers did not turn back on after this. Everything else is fine.
More details:
The speakers were connected to a powerstrip/surge protector. I tried connecting the speakers to a different power outlet, I tried using a different power cable, I checked the fuse it was fine, I even tried bridging the fuse spot but still no response. I pulled out the internals and looked for burned components, everything appears fine. No cracked IC's, no burnt resistors, no popped capacitors, no sign of anything wrong. The power light does not come on at all so I assume the problem is somewhere within the internal power IC's, but not really sure. I opened the wired remote controller and that seemed fine as well.
The only response I got was a little bit of sparks when I bridged the fuse spot with a screwdriver, and the sparks stopped when I switched the power switch to off.
Any suggestions? Creative wants $375 to fix it, the system costs $430... yeeaaaAAaaaahh they really make it worth it to get it fixed? Ugh...
  • 4,889 Answers
The sparks that you specified looks like.. a transformer problem.. And yes they charge 200$ for labor!! The cost of a replacement transformer is around 120$
Posted on Apr 24, 2008
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
Reset after power outage
pull out the plug or just turn it too off for 20 minutes and plug it back in/turn it on. when power goes off the compressor will click and keep trying to restart. this also happens with AC s turn off and let sit usually fixes most of these
Apr 23, 2014 | Whirlpool Refrigerators
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
There was a power outage in the building and now the tv will not come on. The red power light is flashing, that is the only response I get, no picture, no green power light, just flashing red power light,...
You will most likely need a tech to repair the power supply.
You could contact a BIG name repair group, But if you can find a guy like me,
you could get it repaired for the less than $10 costing part it needs and a very fair
labor charge. Us unemployed guys give good deals.
I would do it if you were close.
Toshiba is a notoriously good fix.
Very worth it.
You need a tech.
Jul 26, 2011 | Toshiba 50HX81 50" Rear Projection...
Won't turn on
I had a like problem with a HP printer after I returned from vacation. While mine wound up being dead from a power outage while I was away, make sure the power supplly is firmly connected, also try another outlet, as silly as it sounds. but most likely the power supply failed. You can look for a replacement on a popular auction site and expect to pay up to 10 bucks for a OEM unit.
Jan 30, 2010 | HP Photosmart C7280 Printer
Opener on wall will not work after power outage
Actually it sounds like the vacation lock has been enabled. To turn it off press and hold the lock button for 2 seconds and test it out. If this is not it then you will need to replace the logic board and get a surge protector as well. Thanks BB
Nov 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Gmail Auto Reply
Google HelpGmail HelpGeneral › Setting an automatic vacation response
Going on vacation? No access to the Internet? No problem! Use Gmail's vacation responder to let people know you won't be able to get back to them right away. You can set up a vacation response in your Gmail settings that will automatically reply to anyone who emails you. While the vacation responder is enabled, Gmail will send a response to anyone who contacts you.* If that person contacts you again after four days and your vacation responder is still enabled, Gmail will send another vacation response to remind the person that you're away from your email.
Here's how to let people know you can't respond right away:
  1. Sign in to Gmail.
  2. Click Settings along the top of any Gmail page.
  3. From the General tab, select Vacation responder on in the Vacation responder: section.
  4. Enter the subject and body of your message in the Subject: and Message: fields.
    • If you've enabled a personalized signature in your settings, Gmail will automatically append it to the bottom of your vacation response.
  5. Check the box next to Only send a response to people in my Contacts if you don't want everyone who emails you to know that you're away from your mail.
  6. Click Save Changes.
While the vacation responder is enabled, you'll see a banner across the top of any Gmail page, displaying the subject of your vacation response. To stop Gmail from automatically sending the response, click end now within the banner. Or, if you'd like to edit the response, click vacation settings.
  • Keep in mind that your vacation response will start over each time you edit it -- if someone receives your initial vacation response, and then emails you again after you've edited the subject or body of the message, he or she will receive the edited response, too.
* Messages classified as spam and messages addressed to a mailing list you subscribe to will not receive a vacation response.
*****http://mail.google.com/support/bin/answer.py?hl=en&answer=25922*****
Oct 22, 2008 | Google Gmail
How to reset my Jenn-Air Jxt8836ADS kitchen hood?
According to Jenn-Air (Maytag) if you remove the power from the hood for 15 minutes it will reset the board. So depending on how long the power was out the outage would have done this. There is a good possibility that the outage ruined your board.
Oct 31, 2007 | Jenn-Air JXT8836ADS Kitchen Hood
Creative Labs Gigaworks S750 Computer Speakers Logo
229 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
