Question about Sony Televison & Video
Stuck on child lock - Sony Televison & Video
Try going to the recorder itself (not the remote). Press and hold the stop button until the childlock message goes away.
Posted on Oct 09, 2010
Hot point washing machine WMA76 stuck on child lock
Child Lock
?When activated all the buttons will be disabled and a child will not be
able to alter any wash programme or option settings. Once selected
this feature remains activated, even when the machine is 'off'.
To use this feature press the 'Child Lock' button and hold down for 2
seconds.The child safe icon will begin to flash.When the icon stops flashing
the feature is activated.If any of the control buttons are pressed, the child
safe icon will flash and the machine will bleep 3 times: no alterations to the
control settings will be allowed.If power is interrupted, at any time,pressing
any button will reactivate the child lock feature.
To deactivate this feature hold the 'Child Lock' button down for 4
seconds.You will then hear a bleep and the child safe icon will go out
Mar 27, 2016 | Washing Machines
Hotpoint wf860 stuck on child lock
Hello
To deactivate the child lock function, press and hold the 'Child Lock' button for 2 seconds. Ypu will then hear a beep and the child lock icon will go out.
Feb 07, 2012 | Hotpoint Washing Machines
Child lock stuck in "on" position.
Hello, Welcome to fixya.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Apr 29, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Child lock is stuck on and athe dryer will not turn on. How do yoiu turn off the child lock?
HI!!
Child Lock can be used to prevent your children from undesirable use on control panel while the dryer is running. When Child Lock is enabled, all the button will be locked and Child Lock glows. To lock Child Lock, Press and hold Rack Dry for 3 seconds, A single beep tone is heard and CL is displayed on the status window. To unlock Child Lock, press and hold Rack Dry for 3 seconds again.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Jan 03, 2011 | LG DLG5988 Gas Dryer
I have the 2010 Samsung Washer/Dryer 10kg and it is stuck on child lock. I can not get it off. Help?
Follow this instruction............. ACTIVATING/DEACTIVATING
If you want to activate/deactivate the Child Lock function, press the Soil Level and Signal buttons at the same time for 3 seconds.
How It Works: 1. "Child Lock" can be activated while your Washer is running. 2. Once you activate "Child Lock", all controls (except for the Power button) will be locked until you deactivate "Child Lock". 3. The Child Lock button will be lit while it is in effect. When buttons, other than the Power button, do not respond, please check if the "Child Lock" function is on.
Hope this helps u out!
Nov 17, 2010 | Samsung Washing Machines
My aiko tv is stuck on child lock. I have no remote and dont know how to get the child lock off.
You can try turning it on and pressing all the buttons down at the same time, that sometimes will reset tv's to factory.
May 12, 2010 | Televison & Video
The machine (HVF 344) has stuck on the last minute of the programme and is permanently locked. The child lock has also come on. How can this be solved?
The child lock comes on when you press the child lock key for two second. To remove the child lock, press the same key for 4 seconds, this worked for me when I recently faced the issue!
Feb 15, 2010 | Hotpoint Washing Machines
Maxima 1996 child lock stuck.Evidently, spring is
Child Safety lock was attached to the door handle by a horizontal wire rod . The wire rod had rusted through at a welded join, and had to be rejoined. The rejoining was accomplished with a small clamp.
Jan 26, 2010 | 2009 Nissan Maxima
The child locks are stuck it only opens from the outside
there is a slider switch on the door(between door and frame) that you can lock or unlock the child locks to prevent them from opening the door from inside but still can open door from outside----just slide the lock switch to enable or disable the child lock.
if they are stuck/stiff---you may have to remove the door panel for repair.
Usually they work free with a liitle lubricant(WD-40) to slide easier.
Jan 23, 2010 | 2000 Ford Expedition
CHILD LOCK STUCK ON
I agree with the initial solution, depress the child lock button for at least 3 seconds.
If it does not clear, then try again.
Good luck.
Please rate my solution.
Thanks.
Feb 12, 2009 | Hotpoint WMA74 Front Load Washer
Televison & Video Logo
162 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
