Question about Samsung Blackjack SGH-I607 Smartphone
Phone will not ring even though the profile is set to normal and defaults are reset
  • Samsung Master
  • 17,130 Answers
If even after your deffaults were loaded the ringer does not work then it is possible that there is an hardware issue. You will have to open the phone and probe within for possible failure of the ringer / buzzer, the connections. If your ******** is working then it is possible that the ringer is faulty and must be change. But if any of these are not working then you might have to check the board for confirmation. Use a good multimeter to confirm the continuity of the buzzer/ speaker and the connections / connectors. Hope you get this right. Good day
Posted on Jul 29, 2010
Why doesn't my 9611G phone ring when someone calls
turn the profile to normal and the ringtone to a loud one. make sure the volume is up. ensure there are no diverts set.
You can reset to factory default and setup from scratch if you have difficulties locating the error
Jun 30, 2015 | Avaya 9611G
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
My Nokia 6131 has stopped ringing - it just vibrates when there is a call/text. I haven't done anything different. It's not on silent and I've tried resetting to factory defaults. Any suggestions?
its like the user profile has changed to silent
All you have to do is....
go to the settings on your mobile phone, scroll to profile and select it, click on general or loud, select personalize,check the incoming alert mode and see if it is set to ringing,scroll down and select a tone for the alert then save. after which activate the edited profile as the profile in use..
hope this helps
Jan 25, 2011 | Nokia 6131 Cellular Phone
When the phone rings,it only vibrates and the ring tone is barely audible,sometimes non existent even though the phone is in the normal profile and the ring tone volume is max. it used to work just fine...
TO AVOID THIS PROBLEM KINDLY SWITCH OFF YOUR MOBILE 2HOURS PER DAY. THIS IS DUE TO IMPROPER ACTION OF BATTERY. OR MAKE A SERVICE OF YOUR PHONE. THANK YOU HAPPY NEW YEAR
Dec 31, 2010 | RIM BlackBerry Bold 9700 Smartphone
My Blackberry curve 8330 goes to the quiet mode even though my profile is set for normal ring. Only thing I can do to fix it is turn off and remove battery
maybe see your advance option on the top right corner.
mine goes to quiet mode and i identify which call and/or msg i wanted to receive normally.
good luck
Aug 13, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Wont ring in normal setting.
This is a rather common issue but one that is easily corrected. Motorola phones have different "Profiles" such as Outdoor, Meeting, and as you know, Normal. Each of these profiles have their own separate ringtone settings. To correct the normal settings go to Settings>Profiles>Normal, press options and select edit. This will allow you to set the correct ringtone and other settings for that profile. Once that is done you should be ok.
Apr 20, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Verizon 8330 does not ring
1. Check and make sure you're call forwarding settings are correct. Normally people have it set to ring for 20 seconds, before forwarding to voicemail. Your cell phone company should be able to walk you through what their default setting recommendation is.
2. Is the call making it to the device, but the ringer isn't turned on? Does the screen show INCOMING CALL? If it does, check your PROFILES and find out which one is active and see if the ringer for that profile is set to SILENT.
3. If the call never makes it to your BB, your internal antenna is bad - take it back.. or you get no signal where your at. Basic troubleshooting for the BB should be to pull out the battery. Turning it off completely by removing the battery - should reset any bugs that hose it up.
Mar 24, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Samsung Blackjack SGH-I607 Smartphone Logo
149 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
