Question about A4tech R7-10 Mouse
R7 doesn't work properly
My r7 a4tech mouse doesn't work properly.after attaching the remote part to USB,it doesn't blink and by pushing the button mouse works for 20 seconds and then it stops.No blink/light on remote and no move in screen. i've changed the batteries but it didn't effect.
    President:
  • 8,637 Answers
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 20, 2009
MOUSE WILL NOT WORK
You haven't said what kind of mouse you have or whether it used to work.
I'll offer some suggestions for the most common problems:
If it used to work but now doesn't, try a system restore back to when it did work.
If that doesn't work--are you using a wireless mouse? If so, are the batteries fresh and are they inserted correctly?
If you are using a wireless mouse, have you pushed the little "connect" button on the bottom?
You haven't said, but is the other mouse a wireless one or a USB mouse? If your USB mouse doesn't work, try another USB port. If you go into the device manager, do you see a "human interface device" or a "mouse" listed? If so, it will tell you the system recognizes the device. If that is missing, there is a good chance the mouse is dead.
Oct 31, 2011 | Computers & Internet
I have a compucessory wireless mouse and keyboard. Mouse model 40918. My mouse just stopped working this morning. How do I get it to reconnect?
check the batteries on the mouse
usually on the underside of a mouse possibly under a plastic sticker rub your fingernail across the top to locate a small (phillips screw) star screw make sure they are connected you can do this by spinning them around and fully charged
hope this heps
Oct 25, 2011 | Compucessory Wireless Optical Mouse...
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
GE Optical cordless mouse will not work. Have shut down computer, reconnected the USB to CPU (Receiver), pushed button on mouse. Red light blinks, but will not connect. What else can I do? Have lost...
I have a Logitech cordless mouse but had a problem recently. It fell on the ground and the batteries fell out. Put them back in, the mouse came back on but didn't work. Pushed the button on the mouse several times, no luck. The light at the receiver was always blinking whenever I pushed the button on the mouse, so I assumed that should work. After a few tries, I ended up pushing the button at the receiver and low and behold, the mouse was working again.
Have been using this mouse for years, had that problem only one.
Hope it helps.
D.
May 09, 2011 | GE Optical 98802 Mouse
Hi, my guitar doesn't connect to the nintendo console. The 4 blue lights of the guitar and the usb adaptor light are blinking. My drums are working properly. I have pushed several time the button in the...
You might want to re-synch the remote to the console.
On the remote, the red synch button is where the batteries are installed.
The red synch button for the console is located behind the lip door where the SD card is inserted.
Press the synch buttons and you should be be ready to ROCK!
Mar 14, 2010 | Nintendo Rock Band for Wii
Cannot get the mouse to interact with computer. Have usb plugged into computer. USB is blinking green. The remote glows red when I push any button but nothing happens. I have replaced the batteries and...
You Might want to reinstall the driver first, if this does not work get a PS2 converter to plug the mouse in to the standard PS2 mouse port.
Hope this helps
Mar 03, 2010 | Interlink VP4350 Mouse
A4Tech R7 problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
if that doesn't work try
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Dec 31, 2008 | A4tech R7-10 Mouse
Mouse
Try using an updated software driver for your model.
Just visit A4tech's support and download page HERE.
Choose your model in the drop down boxes.
Download and install and you should be back in business.
Let me know if you run into any problems.
Please don't forget to rate my solution FixYa
Thanks!
Sep 17, 2008 | A4tech R7-10 Mouse
Wont work
IT WILL WORK IS IT A WIRELESS MOUSE
Feb 15, 2008 | A4tech R7-10 Mouse
Powersaver R7 wireless keyboard and mouse
how to connect r7-10 mouse to pc ?do i press something?
Dec 29, 2007 | A4tech A-Shape Keyboard/Optical Mouse...
A4tech R7-10 Mouse Logo
263 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
