Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Water solution does not come out--is something plugged
    Problem Solver:
  • 5 Answers
It could also be due to the brush assembly channels being clogged. Remove the brush assembly and clean channels by running under warm tap water.
To clean the brush assembly/nozzle, turn cleaner off and disconnect from electrical outlet. Slide the two nozzle release latches outward. Remove the nozzle by pulling straight out. Rinse nozzle under running water. Remove debris from squeegee and wipe with a damp cloth. Using finger grips on the brush assembly, pull straight out. The brush assembly can be washed with a mild detergent and rinsed. Do not use pine or solvent-based detergents.
To replace nozzle, make sure latches are out. Align middle section of nozzle with opening on cleaner. While holding nozzle in place, slide latches inward to lock in place.
Make sure your solution tank is full and securely locked in position.
Lastly, if this fails, you can contact the Hoover Service Center by calling 1-800-944-9200 for an automated referral of authorized service outlet locations (U.S. only).
Posted on Jul 29, 2010
Bissell 9300 2 x will not pick up water.What is remedy?
First make sure it's putting out enough water. There can be enough water coming out to get the carpet wet but not enough that it picks up much water. This is most often the problem to most machines brought in for repairs. If it's putting out enough water and can't pick it up there has to be something restricting the suction. It could be a clog or something is allowing air to leak restricting suction. Inspect the areas where the suction comes from the machine, through the dirty water tank all the way down to the floor nozzle.
Apr 20, 2018 | Bissell Vacuums
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Light keeps flashing on top of canister of my Hoover Wind Tunnel but I emptied and cleaned it well. It sounds right when I turn it on then it goes into this sound like something is stuck but there...
sounds like a possible plug ,then when you first start it up the plug gets stuck a gain.
try taking hose off the unit and running water through hose .if water flows good ,check and see if lid is secure when closed.
Jul 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
My vax xl lets out water but when going back it not ****** up water
take it apart and give it a good cleaning - sounds like something is plugging it up
Feb 13, 2011 | Vacuums
I have power but no suction
probably something plugging the hose or where the water goes into the recovery tank
Sep 15, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Apr 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
All terrain steam vac
Try and trace the hose back from the brushes to the pump. The hose could either be disconnected, kinked, or clogged.
Good luck - Tech101
Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Water leak
If you just pruchased this, then it is under warranty, take it along with proof of purchase to a warranty repair shop and have them fix it. If water just runs out, then there may be a seal missing or a water line off.
Feb 21, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Hoover Steam Vac - water leaks
May be an "o" ring missing. Being brand new, it is under warranty, you have a 1 year warranty, so you may want to take it for repair.
Dec 31, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
1,010 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
