Question about Microsoft Xbox 360 Console
My xbox 360 has some static.
Everything is clear on my xbox 360. the dashboard, loading screens. main menus on my games, but when i start to play the games the whole screen has some static. what can i do to fix this? can i get a list of places that can repair this?
  • 10 more comments
  • Wiznatt Aug 18, 2008
    I have the exact same problem with static. Help!
  • Anonymous Aug 21, 2008
    static only when playing a game
  • CH8IS Aug 21, 2008
    staTIC ONLY WHEN PLAYING A GAME
  • ch8is2 Aug 26, 2008
    my xbox 360 has some static
  • Anonymous Aug 31, 2008
    my xbox has static when i paly Call of Duty 4 & Gears of War & Halo 3 when I put up a bubble shield or if there is a lot of cumotion going on like gravlifts or grenades going off.
  • osiris10459 Jan 12, 2009
    Screen is clear during cinematics. Gameplay, however, shows tons of static. I see a bunch of blue dots on the screen whenever a scene is being loaded.
  • Anonymous Jan 13, 2009
    flashes black prisms on sh*t, **** me off microsoft...
  • Anonymous Jan 24, 2009
    same here
  • Anonymous Mar 03, 2009
    my avatar and Halo 3 and other games have staticky lines running through them
  • Anonymous Apr 04, 2009
    iam geting som static i dont know if its the hd component cable or the power cable i cant tell if its even the system. need help dont know what to buy or do
  • Anonymous Apr 11, 2009
    I got the same thing except I get static on my menu rings too.
  • brandonjo430
    brandonjo430 Oct 23, 2012
    It's your tv bro not the xbox I had the same problem the Xbox trigged an effect on the tv and eventually the entire right side of the tv was completely static
Mine doesnt even play games. maybeif i take a **** in the disk tray....
Posted on Jan 05, 2010
I too have same problem dude
Posted on Apr 30, 2008
When I play Black ops it loads but never goes past the black screen after you press play game. I have an Xbox 360 white and I'm wondering is that the problem. When i took it to my uncles 360 it worked...
I have never heard this issue before. You probably have a lager issue then what can be resolved here and might face future issue in the future. Is this the only game you are having issues with?
Seeing that you mentioned you have purchased a hard drive then I would recommend you install the game to your hard drive and try play after that. This will resolve any issues possably of your disk drive possably getting hung up during gameplay.
follow these instructions to get your game installed on your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press Y on your controller.
  5. Select Install to Hard Drive.
    A progress indicator appears while your game is being installed on your hard drive.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Jul 17, 2011 | Microsoft Xbox 360 Console
"the game has stopped working"
i don't know ask game stop or game crazy
Feb 06, 2010 | Electronic Arts The Lord of the Rings...
Band hero cant get it to work on 360 keeps freezing but soon as i put it any other game its fine just that game any1 else have this problem. its happened to me b4 with nhl 2010 to a while back. the main...
TRy the game in other consoles if the game keeps playing up its the game, it may have corrupt data, otherwise you r xbox may just not like the game. Good Luck.
Nov 17, 2009 | Microsoft Xbox 360 Console
Saints row 2 loading problem
try and save the game to your Xbox360 harddrive(HDD) and then run it off that?
Sep 26, 2009 | THQ Saints Row for Xbox 360
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
My X-BOX 360 has disk tray errors.
Try clearing the cache....!
To clear the cache on the Xbox 360 do the following:
* Go to the Xbox Dashboard, select the System Blade, and select Memory.
* Highlight the HD symbol and press Y.
* Press X, X, Left Bumper, Right Bumper, X, X.
You will see a confirmation message to confirm system maintenance, proceed.
Clearing the cache on the Xbox 360 is a fairly simple process, and can be useful if the system seems sluggish, unresponsive, or you just need to get rid of a game update (for whatever reason).
The most important part of clearing the cache is knowing what to expect. All downloaded game updates will be removed. So if you have downloaded an auto-update for a game, in order to play it on Xbox Live you will need to re-download it.
User game saves, profiles, demos, videos, etc. are not deleted during the process.
Cheers
Jun 03, 2008 | Microsoft Xbox 360 Console
Xbox 360 lock-up
First, do not open up your XBOX 360 at all. If you only got it a year ago, you will still have 3 years of free warranty on it.
  1. Try moving you 360 away from the TV and put it a a smooth surface that lifts the 360 up so air can ventilate out. This is usually the main problem.
  2. If this does not work, call xbox customer support at 1-800-4MY-XBOX. (1-800-469-9269)
Hope this helps :)
Jan 25, 2008 | Microsoft Xbox 360 Console
XBox 360 freezing- Not what you think
Your system is headed for the dreaded red ring w/ three red rings. My system started doing the same thing just before this happend. If you have a service plan with it i would suggest returning it and getting a new one.
I tried all the there little tricks as well deleted everything off my harddrive all that good stuff i think it made mine worse. Cuz after all that i turned it back on and bam three red lights and no picture or sound.
Nov 28, 2007 | Microsoft Xbox 360 Console
X-BOX 360 not playing games
Are you sure that in the system settings the xbox is set to Load game instead of boot to dashboard? This will be located on the blade on the far right of the dashboard. If no help, try this: First, a stupid step - Make sure a compatible game disc is in the xbox, and turn it off. If it continues to boot to dashboard upon powering up, you could always try removing the system updates by: 1. Turn the console off 2. Press and hold the small sync button on the front of the console (the one you use to connect new controllers) 3. Turn on the console whilst still holding the sync button 4. By the time it has booted to the dashboard, the updates should be cleared. As the first version of the dashboard did not have the option to boot to dashboard by default, game discs should start normally now. If this is the case, feel free to re-download the updates from xbox live. Hope this helps!
Jun 11, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,214 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
