Question about Filter Queen Defender Air Purifier
2 questions on filters for Filter Queen Hepa AM 4000 Air Filter
2 questions since I have no manual:
1. Can I just replace the charcoal filter if the inside filter looks good?
I didn't have a blinking light even though I used the unit for 1 year.
2. Should I also change the inside filter anyway ?
Noggin
  • 944 Answers
SOURCE: Filter Queen 3000A Defender Air Cleaner Manual
http://www.filterqueen.com/pdf/defender.pdf hope this helps :)
Posted on Mar 13, 2007
SOURCE: Red Light on front of Filter Queen Defender
To reset per the instruction manual: 1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off. If this doesn't work repeat. Note on step 6: the FILTER REPLACEMENT INDICATOR must be flashing when the buttons are pressed the second time. Hope this works...:>)
Posted on Mar 22, 2007
SOURCE: Filter Queen Air Purifier
you can call 1.866.660.0612 Fm Air Inc a Filter Queen distributor will be happy to assist you.
Posted on Apr 17, 2008
  • 28 Answers
SOURCE: Need manual for Filter Queen 360 Air Purifier
I'm going to go out on a limb and guess you want the Defender model and not the Majestic model. I believe the latter is a vacuum. Here's a link to the Defender 360 manual. Best of luck.
Posted on May 27, 2010
  • 10 Answers
SOURCE: Can I just change the
Yes, but keep in mind the warranty requirements:
To receive the full benefit from your Defender ®, replace your filters regularly. • Every 6 months, replace your Enviropure® Charcoal Filter. • Once a year (for Perpetual Warranty*)/up to every 3 years (depending on usage), replace your Medi-Filter® Cartridge.
*Refer to the warranty for information on warranty extension(Perpetual Warranty)
Posted on Jan 03, 2011
Can I reuse the filters of air purifiers?
Yes, you use these filters repeatedly by cleaning and maintaining it properly. If you are cleaning it for the first time then it is recommended that you must take the advice of an expert.
Oct 01, 2014 | Filter Queen Air Purifiers
I want to change filters. please help
Hi and welcome to DixYa, I am Kelly
The only two parts requiring any service are the activated carbon pre-filter and the HEPA filter. No tools are needed. To change either filter, disassemble the unit as shown.
1. Loosen the carrying handle by turning it counterclockwise and lift filter cage cover from unit.
2. Lift HEPA filter and activated carbon pre-filter from the base.
3. Remove the fasteners from the activated carbon pre-filter and remove it from the HEPA filter cartridge.
4. Replace filter(s) as needed, and discard used filters.
5. Wrap the activated carbon pre-filter around the HEPA filter cartridge and secure it with the fasteners provided
Pictures are here:
http://www.american-allergy-supply.com/hd/hwc.htm
Thanks for choosing FixYa,
Kelly
May 25, 2011 | Honeywell Enviracaire 13520 Air Purifier
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
Can I just change the pre-filter because it is full of dust and not replace the main hepa filter
Dec 24, 2010 | Filter Queen Defender Air Purifier
I'm 79 yrs old. I think I got taken advantage of by a fast talking salesman and paid way too much for my Defender air cleaner. I didn't get a manual, and i don't know how or when to change the filter....
Schedule: Remember, to receive the full benefit from your Defender® , replace your filters regularly. • Every 6 months, replace your Enviropure® Charcoal Filter. • Once a year (for Perpetual Warranty*)/up to every 3 years (depending on usage), replace your Medi-Filter® Cartridge.
Filters available from this Amazon seller: http://www.amazon.com/gp/search/ref=sr_in_-2_p_4_19?me=A2XHGJAEAIWR55&rh=i:merchant-items,n:!1063498,p_4:Filter+Queen&bbn=1063498&ie=UTF8&qid=1293951284&rnid=15899471
PDF manual here:
Dec 20, 2010 | Filter Queen Defender Air Purifier
Where and how can I order new filters.
You never need to ORDER new filters for your SUN AIRE purifier unit. Our pre-filter is LIFETIME/WASHABLE 0.5 micron 2-stage electro-static and NEVER needs replacement. Our pre-filter saves you about $100-200 per year in expensive replacement HEPA/charcoal/carbon filters on other units. Made in America and built to last you a lifetime- SUN AIRE purifiers! www.betterair.com
May 04, 2010 | Sun Aire Sun-Aire Air Purifier - Stainless...
I have a Kenmore Progressive 295 air purifier. I
Hi, are you sure about amazon?! I found your part there for 15$ (less than your budget of 25-30$). Take a look again here:
Amazon com kenmore charcoal filter. I hope this was helpful. Cheers
Jan 04, 2010 | Kenmore 295 Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Finding replacement filters
    http://www.totalvac.com/HAPF600.html?zmam=6843742&zmas=1&zmac=6&zmap=HAPF600
    You can actually use the size B....made by Holmes...Also C for the carbon filters
    Oct 22, 2007 | GE HEPA 106653 Air Purifier
    Filter Queen Defender Air Purifier Logo
    118 people viewed this question
    Top Filter Queen Air Purifiers Experts
    Colin Stickland
    Colin Stickland
    dj_wininger
    Level 1 Expert
    steve h woody
    Are you a Filter Queen Air Purifier Expert? Answer questions, earn points and help others
