Question about Jensen JER-323 Remote Control
Need to know how to program a jenson jer 323 with a Sharp tv
    President:
  • 1,932 Answers
Configuring codes:
Turn on the component that you want to set up.
1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
2.Release the component key.
3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you!
1.Turn on the component that you want to set up.
2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
3.Release the component key.
4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
5.Press "0" - "9" The green light will blink as codes are sent.
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed.
7.If none of the codes turn your component off, return to step 2 and start over.
Thanx
Posted on Jul 30, 2010
I need program a new code contro JR 323
I found the codes in this page http://remotefinder.rca.com/
Codes for Jer 321, Jer 323 and Jer 422.
To introduce it to your universal control Jer 323:
1. Press the device button you need (for example, TV)
2. Press the input key and keep pressing it while introducing your code (for example, Sony Tv: "Input+1218")
Jun 02, 2010 | Jensen JER-422 Universal Remote Control
Remote codes for jenson remote jer 323
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Mar 23, 2010 | Jensen 143307 Remote Control
Jenson remote
http://www.remotecentral.com/features/r-jr300.htm
Sep 11, 2009 | Jensen 143307 Remote Control
I need the codes for jenson remote JER 323
NECESITO EL CODIGO PARA MI CONTROL REMOTO JENSEN JER323 PARA UNA TV SONY
Jul 02, 2009 | Jensen JER-323 Remote Control
I have a jensen 323 remote & need help programming it for a sansui tv. Larry
I have a Jensen Universal Jer 323 remote. My TV brand is Sharp how do i program it and what code number do i use and also instruction for it.
Jun 26, 2009 | Jensen JR300 Remote Control
Lost manual
Hi Iam Vortash your manual is available on this site maybe for free some are ..http://www.safemanuals.com hopr this helps Regards Vortash
May 14, 2009 | Jensen JER-323 Remote Control
Jizzz i´m desperate!!!!
jenson 300 series Sony tv codes 497,491,475,459,406 or the code you have
hold the program or setup button untill it blinks. select the tv function and enter the code you have or one i listed above then enter
Or if your remote is this 300c series your code would be 0000
you would press down and release the device"mode key"tv,vcr,ect
the red light will blink once.press and hold down the setup key untill red light blinks twice then release.enter the code the led light will blink once on each digit execpt the last one will blink twice to confirm valid code ****mode 1 is for the tv on this remote.
hope this helps
Mar 18, 2008 | Jensen JER-323 Remote Control
Jensen Jer-323
Thanks for the code to set the code you must hold down the tv button while pressing the code and the power button should light up after dailing the 4 digit code
Sep 07, 2007 | Jensen JER-323 Remote Control
Televison & Video Logo
120 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
