Question about JBL Reference 410 Headphones (Black)
JBL 410 headphones broken
Hi! I have a pair of JBL ref 410 headphones that i accidentally broke. The plastic connector piece holding together the head band and the ear piece snapped into 2. i was wondering if JBL has these parts as spares, and if i could get my headphones repaired at the local service center? Thanks
[IMG][/IMG]
[IMG]http://[/IMG]
  • 5 more comments
  • shubhamk Sep 03, 2008
    hii i have the same problem..
    i bought jbl 410 and it broke the very next day from the joint where it connects the headband..the joint is very weak..
    can i get a replacement from jbl??
  • gdulling Oct 05, 2008
    I just did the same thing and I tried to superglue it but it won't hold...Please help because I love these headphones.
  • Anonymous Oct 08, 2008
    I've got the same problem, tried to get the part but no one could help it may be a small thing to the company but customer help and assistance go a long way...are ya listening JBL
  • Anonymous Oct 21, 2008
    i also have d same poblem...i tried to stick it with glue...it got sticked but after a few days its right head phone was working but d left one was not...maybe becoz of d glue d wire got damaged...
  • ChrisIngram.net
    ChrisIngram.net Nov 02, 2012
    I was able to drill a small hole up through the cylinder-shaped chamber leading to the ear piece and then epoxied a metal screw into the broken area. Worked for me
  • Anonymous Mar 23, 2014
    help me out
  • Vignesh TV
    Vignesh TV Mar 23, 2014
    wer can i get the spare parts??
The same happened to me. JBL says that repair services are not available for this product according to their website. Their suggestion is to buy a new pair!!!!!. What a shame. JBL products are quite good but the post service is ****.
Posted on Jul 13, 2009
After this happened to me, it felt like a real shame to throw these out when the drivers were still perfectly good. So I bought a pair of cheap 40mm headphones and transplanted the JBL 410's drivers into them. The fit was perfect and I can continue to enjoy that beautiful, bass-heavy sound.
I would think that any pair of 40mm headphones where the cable goes into each side should work. I swapped them into a Zumreed ZHP-005 knock-off for less than $15, and I'm sure there a lot of options out there for that price or less. If you've got some soldering skills, you could probably get the JBL 410 drivers to work with headphones where the cable is on one side (like the Urbanears Plattan, Panasonic RP-HTX7, etc).
Posted on Dec 13, 2011
The cord that goes into the right earbud is broken. But the problem with fixing it is that the break is right by the earbud where the cord goes through the metal piece.
ear bud is glued so it can be cracked open with a razor but be careful ouch... the wires in headphones are hair thin so you have to be careful as there are 3-5 wires that have to be seperated then soldered..difficult. If its less than 1 year and major brand most are warranteed for a year call the manufacturer and ask.. But yes if you are good with solder then you can fix
Nov 25, 2014 | JBL J33i Premium In-Ear Heaphones with...
Hi there! I have a jbl reference 410 headphone and the volume slider on its cordis not working properly. No problem if its on maximum volume, but when i try to move it towards minimun, the sound gets...
You may want to return it to the store as soon as possible, before your warranty runs out to get a new pair. It seems to me that there was a problem with them at the factory in which they were produced.
Aug 18, 2010 | Audio Players & Recorders
Plastic connecting left headshell broke apart
If the tape holds it in place then I suggest a good brand of superglue might hold on for a time. The only other cause of action I can suggest is visiting a Pioneer service center and seeing if the part is still made.
If all else fails have a look at the bottom of my tip on repairing dodgy cables and plugs, there is a suggestion on what to do with a broken headshell.
May 11, 2010 | Pioneer HDJ-1000 Professional Headphones
Bose TP-1A Headphone replacement parts
Broke headphoneTP1 need just the part that the head phones are held together with
Apr 25, 2010 | Bose TRIPORT® Headphones
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Slft earcup on QC3 broke off
They will give you a new pair for $100, even if it has been longer than a year...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Apr 16, 2009 | Bose QuietComfort 3 Acoustic Noise...
HOW TO GLUE POLY CARBONATE
You might try using two part epoxy. It comes in two tubes and you follow directions to mix one drop of each together to make the epoxy to use to glue the parts together. For best results the parts glued together shouldn't be disturbed for 24 hours. I have used the Locktite brand with good sucess.
Apr 09, 2009 | Skull Candy Hesh Stereo DJ Headphones -...
Need Replacement rubber band for wireless headphones JW160R
I to broke mine and couldnt find a replacement part anywhere! called xbox and every game store and no one sells them. What i did was go on Ebay and bought a Broken AS IS Headset for $8 and took the earpiece from that and put it on my working earpiece. Thats the only way to get a replacement part trust me!
Mar 26, 2009 | Audio Players & Recorders
JBL Reference 410 Headphones (Black) Logo
1,352 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
