Question about GE GSL22JFPBS Side by Side Refrigerator
Its not freezing anything and making noise like its trying to start
  • 103 Answers
Defrost switch sensor inside the back panel could be faulty replace it its cheap and look for the compressor relay and and switch. these will be on the side of the compressor. access them by removing the bottom panel on the back of the fridge. test or just replace these can also prevent the compressor from cycling on to start cooling.
Posted on Jul 29, 2010
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
ATB1935HRW
hi john.not freezing could be anything but i would start by checking if u have any ice build up in the freezer.if yes defrost everything first completely and try.if ok great.if same again after a few days then i think your problem will be either 1-defrost timer 2-defrost heater 3-t/stat 4-if not iced up at all check door switch/fanmotor 5-check/clean condensing unit 6-check cond/fan 7-check motor (visual/feel/noise (hot or cold and running noise) 8-condenser warm(if cold could be lack of refrigerant;internal leak or motor)hope this helps good luck.Ali
Jun 30, 2012 | Amana Refrigerators
Picture freezes while dvd player playing
The problem is in the laser pickup assembly, the stepper motor that moves the laser is sticking on the worm gear or excessive ware on the gear linkage is preventing it from moving.
Mar 14, 2012 | Samsung SWA-4000
Not freezing and making a noise every 20 seconds
It is one of the common problem that occurs in the refridgerator.
It can be due to the faulty start relay or the compressor.
Jan 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
While playing the game, it will suddenly make a loud sound the freeze up. What can i do to do fix this?
I have the exact same problem when I play Lego Batman on my Wii. Unfortunately, since the Wii version is the same as the Xbox 360 and PlayStation 3 versions, it has lots of data that the Wii console can't handle sometimes, thus making that loud noise and freezing up. You can't fix it, but the best solution would be to:
1) Unplug the Wii, then plug it back in.
2) Start up the game and try that same part again. It should work. If it doesn't, just keep trying.
*Note: When you plug it back in and start the game again, don't do any other levels before the level that keeps freezing up and making that loud noise. I hope this helps.
Sep 27, 2009 | Nintendo Wii Console
Compressor making noise and freezer is kicking cold air out but
Sounds like the start relay, start capacitor and overload have become defective. Turn it off to prevent further damage to the compressor internal overload. Check to make sure the condenser fan and the evaporator fans are running and get back with me with an answer yes or no. Thanks, Sea Breeze
If the model number you have above your post are correct I will also send you part numbers and hot to replace.
Aug 04, 2009 | Maytag PTB2154G Top Freezer Refrigerator
Weird clicking noise and computer freezes.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
Jan 29, 2009 | Acer Aspire 5100-3357 Notebook
Sa-mt1, picture freeze after ab 50 min-1h,than stops;
First of all,if you are using rental dvds, there might be scratch which your dvd player might have an issue to read it;however,if you have tried many dvds in this player and you are having this issue, it is time to move on to another dvd player.
I recommend a Pioneer dvd player.
solutiondoct
Oct 25, 2008 | Panasonic Home Theater System System
GE GSL22JFPBS Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
