Question about Kenmore 61042 Top Freezer Refrigerator
On my kenmore refrigerator mod number 25374879401 the freezer is cold and the bottom is not cooling.the condenser fan is running as well as the one in the freezer.any help would be appreciated
    President:
  • 1,891 Answers
Ck the back of freezer for ice build up there should be no ice . if so the defrost heater has failed or the drain is pluged . . thes units often need drain heater's to prevent the problem .. mm
Posted on Jul 29, 2010
Kenmore Elite 596.75523400, the refridgerator is working but the freezer isn't. The freezer defrosted but the freezer fan is working. Thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
The refrigerator and freezer are not cooling the freezer reads 12 and the refrigerator is 42
I am a celcius man myself. So I assume you are talking about degrees fahrenheit?
Basically you are not getting the correct temperatures in the refrigerator or freezer. this could be due to
# Condenser fan not working (condenser is the outside of the fridge that gets hot)
# condenser blocked or dirty
# Poor air flow over the condenser
$ evaporator fan not working (this circulates cold air inside the fridge)
$ The ducting for the cold air is blocked
$ the themostat is faulty
& Compressor has burnt valves and cannot pump properly
* the fridge is loosing refrigerant
Mar 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Ref. Not cooling both top and bottom not freeing food. Fan running
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
dathju
Jun 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Top refrigerator not ccoling and bottom freezer
check the condenser temperature when the compressor is running by hand it must be warm or hot if it is not then that means no refrigerant left in the system.This can be a possible cause.
Sep 27, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer makes a humming noise and is not freezing
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer and fridge not cooling well i clean the condenser fan
heatman101
,.f
Mar 13, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 61042 Top Freezer Refrigerator Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
