Question about GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer
Our dryer does not heat as a result of temporary flooding in basement....is there a pilot light on this model?
  • 171 Answers
Haven't been pilot lights for a number of years.  it could be a number of things including the ignitor, gas valve or thermal fuse.  i would start with the thermal fuse and then the ignitor..
Posted on Jul 29, 2010
RELAINCE 606 GAS WATER HEATER. WE RECENTLY HAD THE BASEMENT FLOOD DUE TO ALL THE RAIN. WE NOW HAVE NO HOT WATER, I AM SURE DUE TO THE FLOODING, BUT CANT GET THE PILOT LIGHT RELIT! HELP
If keeping the thermocouple bypass pressed keeps the gas flowing to the pilot but the flame goes out when it is released in spite of keeping the flame going the customary amount of time, then either the flame isn't powerful enough to reach and heat the thermocouple bulb, the pilot flame or the bulb is out of alignment or the thermocouple is faulty.
If the flame is weak it indicates a blockage in the jet or the supply pipe.
Sep 08, 2017 | The Kitchen Appliances - Others
Had a flood in the basement. THe electric motor works by there is no heat. Turned on the main and cutoff valve to the dryer started the dry it tumbles just fine but still no heat. Don't think...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | GE Dryers
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
My basement flooded and now my gas water heater
Was the gas valve under water? If so it must be replaced. If not, and you're sure you are holding in the button for at least 30 seconds after the pilot is lit, the pilot will need to be removed disassembled and cleaned. Also, the thermocouple may or may not be bad, replace it anyway (for the cost @ Lowes etc just not worth it).
Sep 22, 2009 | Water Heaters
Flooded and not heating now
There is no pilot light. You probably got water into gas jets, also all electronics to ignitor need to be dryed. Also blow out all gas parts. If dryer was plugged in at time of flood you could have shorted one of the thermal switches behind back cover. Check all of this I wrote.
Aug 17, 2009 | Hotpoint NVL333GY Gas Dryer
Finding pilot light for a Kenmore dryer model # 97581110
theres no standing pilot in dryers is it on a heat setting or air dry .then look thru that small hole while in aheat setting on the timer. when you press the start button you will hear two clicks the see the glow ignitor glowing.if its not glowingyou would need to check voltage at the ignitor if no voltage problem will be thermol cut out fuse
Jan 01, 2009 | Dryers
Dryer won't run.
First, there is an excellent chance you have some kind of flood damage insurance.  It may pay for part of the repair.  You did not tell us what is not working but I'll guess it is the motor.  On many models, there is a switch on the motor which will not allow the elements to heat unless the motor is powered and running.
Dec 19, 2008 | Kenmore 63942 Dryer
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Logo
94 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
