Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not working. Ice maker is working. Started noticing the past 2 weeks that ice cream is melting. Refrigerator is working but not keeping things really cold. The unit is only 3 years old.
    President:
  • 1,891 Answers
Ice mker will soon quit as when ice cream is soft the tempt is rising . look for frost build up in back wall of freezer . if so the heaters have failed ( very common ) . they will have to be replaced . there is a new style that replaces mose G E heaters . and they are much better .. mm
Posted on Jul 29, 2010
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
Ice melting in ice maker
Remove the food from the lower shelves , so the inside rear lower freezer panel can be removed ( only 2 or 4 screws ) .
The # 4 thermistor or # 5 thermistor is bad . # 4 tells the main control board , the temp of the coils , if they need defrosted and when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on , due to temp setting .
May 01, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Mar 21, 2009 | Samsung RS2630SH Side by Side Refrigerator
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Jun 24, 2008 | Maytag MSD2756G Side by Side Refrigerator
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
GE (PSS26MSRSS) Side by Side Refrigerator Logo
202 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
