I have Coonara 1900 inbuilt was wanting to know how to change door seal around the glass i have the seal but not sure how to remove the glass from the door without breaking the glass
  • 60 Answers
SOURCE: rubber seal removal
There is a spring at the bottom center of the door gasket. Stretch that out and a wire will come off from around the gasket you can then pull the gasket off and reach in. Be sure you get the gasket back on all the way and the wire right or it will leak. Good luck.
Posted on Feb 16, 2008
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
  • 1861 Answers
SOURCE: How to remove trim from rear hatch door on 2001 Sienna
You need to remove the big plastic or vinyl rear hatch trim to get the side trims off. Remove the 10 mm bolt that holds the pull handle (if you have a pull handle), and then, using a flat tool, (like a stiff putty knife), insert the tool between the vinyl trim and the tailgate to loosen the plastic clips (there is like 18 of them); one the hatch panel is off, you will see that you can now remove the side trims.
Posted on Oct 27, 2008
SOURCE: zippers get caught in seal around dryer door and twist around and break off
I had the same problem with zippers and socks. Solution was as simple as replacing the felt seal at the top of the dryer door.The drum rides on the felt seal that has plastic guides imbedded in it. It's function is to seal and more importantly act as a guide for the drum.
Check the drum at the front edge if the gap around it is not the same or if the drum is wobbley when you lift it by hand that is probably the problem.
You will need to open the dryer cabinet. Mine had 2 catch springs at the front top edges that were released by pressing with a thin flat object that will fit between the top and bottom cabinet(butter knife). Once the top can be lifted you may find a couple of screws that secure the front panel and door. Once removed the front panel can be popped off and lifted out (careful of door switch wires).At this point you csn see the felt at the top of the door . It is glued in place and is easily removed. your local appliance part supplier can supply you with a replacement that comes with the glue and installation instructions.
Put the dryer back together and no more burnt socks and ruined zippers.
Posted on Mar 04, 2009
SOURCE: Resealing Inner Oven Glass
I guess you worked this out already as posted a while ago....but for others like me I thought adding a solution might help..........Open the door fully and on the hinges there is a clasp, flick that back on itself on both hinges. Close the door carefully and it will stop half way....now lift the door off the hinges. Lay the front of the door on the floor and there are 4 screws on the bottom of the door...unscrew the middle 2 (the outter 2 attach the hinges). then lift off the back of the door....you now have the access you need!
Now i have done this I need to get the sealant....is there a shop you can get this from B
Posted on Oct 09, 2010
I need a new door or just replace glass. I have a coonara fire heater any suggestions
the glass will be heat resistant pyrex glass so unless you can get the glass heat treated , get a new door
May 06, 2017 | Ovens
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
Hi, wondering if you could provide any information on how to remove the rhr door glass from a 2014 jeep Cherokee.I have the door completely stripped except for the door glass,can't seem to get it out
you will need to raise the glass , manually, until you can access the bottom of the glass where it connects to the opening mechanism and release (if not already at this stage) ,if you want the glass out of the door completely then you have to remove all the trims along the edge of door(weather strips) and around window/door frame , the seals ,the window will then be able to be lifted out , carefully !!
Oct 27, 2014 | Cars & Trucks
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
Aeg oven door
Most of those glass panels are a sealed pack and are not able to be separated. Usually there are screws around the edge of the door that holds the door together and if you were going to replace the glass you would take those out to separate the inside panel of the door from the outside of the door and that would give you access to the glass area. You could try that but I do not know for sure if you will actually be able to separate the glass to clean it.
Dec 03, 2013 | Ovens
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
Water
Since is should not be the heater core,(and coolant - since you don't mention losing any) it is probably either the door seal or the winsdshield seal that is leaking. And I assume that the floorboards are not rusted out either. You can take a hose with water, (and the floor boards dry) and run some water on the windshield, and around door opening and glass to check. If the winshield has been changed, and it leaks, it can be sealed without removing the glass with windshield sealer or the commercial windshield adhesive, which is what I use to repair one that didn't get enough adhesive the first time. If the leak is around the door, you will need the get the seal from the dealer or have it changed at the mechanics shop. I use the proper adhesive on these. Hope this helps. Rick
Apr 17, 2009 | 1996 Mercury Grand Marquis
Side door glass removal
ok first thing first if you can spend roughly 80.00 I would call a mobile glass company or look for a van that does glass. They will do it and they can take the old one out and replace it within an hour/ the reason I say this is they need a chemical to bit into the your door and urethane it in now think of this 80.00 for glass guy or 10.00 for the chemical for bite one tube of caulk 30.00 plus your time and its pretty valuable and the professional put in hands down is the thing.You will appreciate this that i am teeling you.Hopefully you thought of that.I know you can do it just the but thing. if you need any more info go to collisionrepairadvice.com ok jmdf
Mar 09, 2009 | 2002 Chevrolet Astro
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
