Question about Danby DPAC120068 Air Conditioner
My air conditioner is leaking from the front of it
My air conditioner is leaking from the front right corner. how do i stop the leak?
  • Hannah Schroeder
    Hannah Schroeder Oct 11, 2017
    It's funny that your air conditioner is leaking from the front right corner. Mine is doing the same from the back right corner. I don't know if our units have the same problem if the location is different, but I think we should both hire an air conditioning service to see if it can be repaired. http://www.ronhammes.com/services
  • 2,063 Answers
Tilt it to the bacj
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Oct 11, 2017
  • 21 Answers
Are the three drain plugs tightened?
If you're stumped, try to drain the inside tanks and see what happens: Unscrew the three drain valves at the back, and put a pan to catch any water (only a few cups). Let us know what happens.
Posted on Aug 14, 2010
2 Suggested Answers
  • 387 Answers
SOURCE: Friedrich room air conditioner Model
make certain that it is tilted ot the outside about 1 inch or so .. service filter while your at it as well
Posted on Jul 23, 2011
AC does not blow cold air.
Hello, all the refrigerant most likely leaked out. To fix a leak it might be a bit expensive, sometimes to repair a leak will cost more than to buy a new unit.
Jun 20, 2012 | Friedrich XQ10L10A Air Conditioner
Friedrich room air conditioner Model SQ06J10: leaking water from front bottom right corner
Jul 23, 2011 | Heating & Cooling
THE AIR CONDITIONER LEAKS WATER FROM THE FRONT OF THE UNIT.
Look for the drain line coming out of the unit typically in the bottom. Clear out this drain line with a vacuum or water hose. It should begin to drain and stop leaking.
If the leaking continues, you may have a cracked drain pan or severe drain blockage.
Jul 31, 2010 | LG Goldstar GWHD5000 wall/window Air...
I have a Simplicity 12000 BTU air conditioner and it is leaking water from the right corner on the bottom of the unit. The water does not travel to the storage tank.
a pipe is a=puntured, b=the securing clamp is loose and needs tigning,,c=the matrix element has cracked,needs changing,remove cover to see where the leak is
Jul 09, 2010 | Heating & Cooling
Hi, Our Mitsubishi Air Conditioner is leaking from the bottom left hand corner. The conditioner will sometimes run for 1hr then start leaking, or a few hours then start leaking. We're aware it could be a...
Two ways to clear out the pipe. One way is to take a wet/dry shop vac and **** from the outside drain pipe. The second way is a bit messier. Take an air hose (from a compressor) and purge the air up the drain a few times. Works like a dream!
Jan 27, 2010 | Mitsubishi Heating & Cooling
Water leaking out of unit, not out of flow tube.
Some models have a hose, some don't , maybe the drain hole it's restricted, condensor normally it's in the back of the unit, you might have to remove one of the side panels.
Dec 23, 2009 | Convair Portable Air Conditioner
97 Grand Cherokee Ltd. air conditioner does not stay cold.
there is a new product out called red angel ac stop leak and conditioner, it is amazing , you can get it at advanced auto
Jul 01, 2009 | 1997 Jeep Grand Cherokee
Hard top problem: 1991 Mercedes 300 sl (Leak on corners in front)
Just had mine fixed last week. Your hydrolic hose is busted and once all the fluid leaks out, your top will STOP working. Mine stopped in mid-air!!! We had to put it up manually which was NOT easy. Also, the fluid leaked and ruined my leather headliner. Cost to repair convertible top was approximately $800.
Nov 19, 2008 | 1998 Mercedes-Benz SLK
Wall unit leaking water in the front
The problem is in the lines that run from indoor to outdoor unit.
You need to make sure all lines are slightly sloping towards outdoor unit
Jul 20, 2008 | Friedrich QStar SQ06J10 Air Conditioner
Danby DPAC120068 Air Conditioner Logo
460 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
