Question about Craftsman Garden
I need a manual for a craftsman gas weed trimmer. It came with my house. Seems to have run out of string and I can't figure out how to get the reel out of the thing. The model number is 316.795000. I googled, but the only place I can find the manual is on a place that wants $60 for it. Even Sears doesn't have it.
SOURCE: Black & Decker 8209 Weed Trimmer
I fixed mine, but this thing won't let me post. If I have to be a member just to make a suggestion, my suggestion would be 'let me post my suggestion'. Do you think everyone passing through here is a member? Some of us would rather not sign up, but still have something to contribute. anyone out there to hear this?
Posted on Jul 20, 2008
steve_lima
  • 181 Answers
SOURCE: repair a weed trimmer, How to remove the starter clutch
down in the center of the clutch there is a screw that holds everything to gether.usualy it's a torx head screw.some are reverse thread so be careful.hope this helps,let me know
Posted on May 13, 2009
  • 57 Answers
SOURCE: Spark plug gap?
.030
Posted on May 18, 2009
I went to the B&D web site and downloaded the manual for this unit.
Here is the link
http://www.blackanddeckerservicenet.com/Products/ProductManual.aspx?q=8209
Posted on Jun 29, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Restring bolens bl150
There are two ways to re-string a weed trimmer.
  1. Wind new line on the inner reel
  2. Install a prewound inner reel
Check the owner's manual below for detailed instructions.
Bolens BL150 Manual
Mar 31, 2012 | Garden
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weed wacker started and wacked some weeds then the strings stopped rotating but engine very strong
pull off string housing check that all parts are there. run machine and see if shaft is turning-- if it is then put housing back on sometimes I havent put the housing on properly. if shaft is not turning. then repair is needed. or just buy a new one. cost of repairs on this stuff is not worth the cost. unless it's a profesional grade machine..
Jun 18, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
I have a sovreign 25cc trimmer and was wondering where the idle screw is on it any ideas
Go to the Sears URL page listed and click on the sears number you find on your string trimmer and see the exploded parts of that model.
http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts
Apr 02, 2011 | Craftsman 25cc Gas Line Trimmer
How do I reload the trimmer line?
Depending in model usually they sell a cartidge reel with line allready. If your handy savy! you may doit yourself. Turn your weed eater around make sure & carefull with your gas spills out. The reel usually locks counter wise pull it carefully and it pos out, the get the right line size, depending in the size os reel you could go a few rounds with line make sure that one ends come out one hole & the other thru the other hole. It just snap in the reel and counter closed to lock.
Time for the GREEN man to come !!
Jun 29, 2010 | Craftsman 25cc Gas Line Trimmer
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
Garden Logo
93 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
