Question about Tippmann 98 Custom Marker
I bought my tippmann 98 used the co2 tank is filled i hear the gasgo in the gun but wont fire. the bolt works fine but wen you put the gas its as if you shot without the gas
    Problem Solver:
  • 15 Answers
Try turning up the velocity on the marker.
Posted on Feb 07, 2011
My paintball wont stop shooting but it has nothing to do with the co2 tank help?
The sear is not catching the bolt and resetting it properly. Or, there is not enough air pressure to push the bolt back to its original position. I would take it to a gunsmith. Parts fly out of a Tippmann if you open it up.
Jun 16, 2014 | Tippmann 98 Custom Act Paintball Gun
My Tac-5 Recon marker does not shoot the paintballs. I cock the marker and after I pull the trigger I can feel and hear the spring action but no paintballs are launched. When I attached the CO2 tank I did...
take the hammer and bolt out, clean them and oil them with paintball oil (no motor oil or WD-40)
air tool oil also works, but besides paintball and air tool oil, never use anything else.
the bolt is in the front of the marker, it is what pushes the paintball from the breach into the barrel. the hammer will be towards the back. its been years since i have touched a tac-5
easiest way to oil is just to put a few drops in the asa (where you attach the tank) and dry fire with the barrel off a dozen times. this will get the oil everywhere it needs to be.
if you can take it apart and clean it i would still recommend that
Jan 05, 2018 | Tippmann A 5 Standard Paintball Gun
New Project Salvo. Second day tried to use it fires like it is on full auto for a second or two. Wont shoot as semi auto . It drains the CO2 quickly and sometimes the trigger gets stuck on full auto. ...
It's vary common for places to not fill Co2 tanks correctly and it sounds like this is your problem. Try having your tank filled in a different store, If this doesn't work you should exchange the gun at the store you bought it or call Tippmann, they have a excellent 2 year warranty.
Sep 09, 2011 | Tippmann US Army Project Salvo Sniper...
I have response trigger on my a5 and only shots one shot at a time when pointing straight. When i raise the gun to the air and shot it response trigger works. What could be the problem?
If you are using CO2 it may be affecting the system. With a gun down straight, you could draw liquid CO2 into the internals. A siphon tube can be installed in a CO2 tank to stop or manage this. If you have access to someone's air tank, try using HPA (high pressure air aka nitrogen). If it fires fine with air you have deducted that the CO2 is to blame. Simple. Switch to air. It's better for the gun anyway! Now if the air didnt change anything I would think a component of the response trigger system is to blame. I am not familiar with the response trigger( I use E-grips) but I would think that a part that may slide or move forward or bak when you lift the gun up would be to blame. Most local shops should be able to diagnose the problem. I did find an installation video by Tippmann on youtube.
Here is a link.
A5 response kit installation
Mar 31, 2011 | Tippmann A 5 Standard Paintball Gun
Just bought a tippmann 98 act took it home went to test and it still broke like everyother ball. Is it the balls or possibily to much veloicity? does it make a difference co2 or compressed air?
The velocity adjustment is probably way too high.
This causes too much propellant to enter the firing chamber.
There should be an Allen screw on the side of the gun where
you can adjust the velocity. Try backing the screw out a turn and see what happens.
Here is your owners manual to help you.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
CO2 is very hard on O-rings so if you can use air you are better off.
I use an A-5, Autocockers, Smart Parts Ions and more.
Mar 06, 2011 | Tippmann 98 Custom Act Paintball Gun
I attempted to put a car stock on my Tippmann 98 custom and took apart the gun but the stock didnt fit, now when i put it back together and shot it with my tank connected the gun wont stay cocked and...
Check the O rings on the big metal striker, make sure that you have the spring on the back (where the stock would have went) in the right hole on the back plate. Make sure that your velocity is set to a reasonable level.
Oct 02, 2010 | Tippmann 98 Custom Act Paintball Gun
98 Custom Act Paintball Gun: i have just brought a 98 tippmann custom and it ha...
Basically speaking, air is air. Now it's the pressure that's the concern. co2 bottles use a regular valve that has a pin in it and opens to allow the gas through. High Pressure Air - HPA is the same concept but since the pressure with co2 is built up by expanding gas, HPA has to do it with pressure only. So the tank is pressurized a LOT higher than co2, but there's a regulator on the tank valve to bring the working pressure into the marker to the proper level.
So yes, you can use "air", but you need to make sure it has the right output for your marker. (i.e. not a low pressure HPA valve.).
You'll have the same problem though, getting someone to fill the bottle. Check with your local airsmith and paintball fields and stores. If they have co2 they would have HPA, but some do only deal with HPA since it's "easier" in some cases.
You may have to check around. Sometimes hardware stores have a small section in back, or you can check with the paintball places around to see if anyone in your area is equipped. Some teams have their own tanks, especially if there's not a place to get fills locally.
There's also online communities like Brigade and various paintball sites where you can check around for other players. Someone may have a co2 fill tank, a scuba tank for HPA, or a group that gets tanks together to make a run and get them filled somewhere.
Play hard, play safe, play with honor!
8^)
May 18, 2010 | Tippmann 98 Custom Act Paintball Gun
In cold weather it wont fire, it acts like its running out of co2 it goes full auto.
make sure you replace all of the internal o-rings for commpression. one may be worn slightly and contracts when cold allowing gas to escape
Jan 09, 2010 | Tippmann 98 Custom Act Paintball Gun
Tippmann Custom 98 simply NOT WORKING
  1. Home page | Special Ops Paintball SPECIAL OPS - A-5-A2 COMMANDO EZ-KIT. Regular Price: $ 79.95 ... Special OpsPaintball is a proud sponsor of the Living Legends scenario paintball game. ...
    shop.specialopspaintball.com/ - Cached - Similar
    Forum Brigade Tippmann A-5 Upgrades Gear Vests Articles Sick Deal Tippmann X7 Upgrades Markers More results from specialopspaintball.com »
    YOU NEED TO BUY A RE-BUILD KIT ITS CHEAP HERE.
Oct 04, 2009 | Tippmann 98 Custom Marker
Tippmann 98 Custom Marker Logo
167 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
