Question about Singer 7426 Mechanical Sewing Machine
I have a Singer 7426. The needle is hitting the hook area incorrectly, making a jerking motion with the needle along with a tapping noise. Any idea how to correct it?
  • Singer Master
  • 7,365 Answers
The needle probable is bent-has to be replaced so it won't damage the needle bar
if the needle is hitting the needle plate then it needs to be check for burrs, small burrs can snag the fabric
Posted on Jul 29, 2010
Singer 7426 neddle is to low for auto needle threader
Make sure you have the correct needle for your machine. The wrong needle can cause major damage to your machine or the threader. Check your needle for size and type for your make model and use of the machine.
Cheers,
Embroidery Services
San Diego, CA
Sep 14, 2017 | Singer Sewing Machines
When the hand wheel is manually operated it then makes a clicking noise near the presser foot
Have you tried a brand-new needle? Frequently, a bent or damaged needle will make noise.
If you are able, hand turn the handwheel and watch the needle and hook action. You may see the needle hitting. Or try removing the needle and listen if the sound continues. If it doesn't, then it's the needle. If a new needle doesn't cure the problem, could be the needle/hook timing is off. May need service.
Apr 30, 2016 | Singer One Plus Computerized Sewing...
How do I stop my singer prelude sewing machine from making so much noise?
Reset all dials. Straight stitch, 1 or 2 in length, ease the thread tension and see if it helps. The only area that makes noise is around the bobbin/needle part of sewing machines.
Feb 18, 2015 | Singer Sewing Machines
Sewing along with straight stitch slight sound and it refuses to sew. I must pull it to get it to move. then it makes a little noise begins to sew straight. Then repeats the same slow down. very...
Possible problem is the machine has thread caught in the hook area, or the feed dogs are packed with lint. Remove the needle plate and clean out all thread and lint.
Oct 07, 2013 | Singer Sewing Machines
I cannot get the top needle thread to pick up the bobbin thread on a Singer 404. I have the manual online and can see that I have loaded everything properly, but the bobbin thread just sits there when I...
Hi Jennifer:
Do you understand how a stitch is formed on a sewing machine? The needle goes down to its full down position. At that point the shuttle hook should be pointing right at the needle scarf, ready to go past it as the needle starts to go up.
When the needle starts its upward travel it forms a loop... the shuttle hook enters the loop and the bobbin thread is "captured" in that loop.
If your machine's timing is advanced, the needle will hit the hook and break or make nasty thumping noises. If your timing is ********.... the hook misses the loop entirely and does nothing.
So... open up the entire bobbin/throat plate area.... take the foot off so you can see. Clean if necessary. Then turn the hand wheel by hand until you see that the needle is at the lowest point of travel. Where is the shuttle hook?
From there you'll have to use your logic to find the right screws and adjust the hook.
Here' is a Parts Chart for your machine.
http://www.parts.singerco.com/IPpartCharts/404-1_4_5.pdf
Sep 14, 2012 | Singer Sewing Machines
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
The machine needle is no longer in the correct position
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Sep 01, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Singer 7426 timing off
Aug 25, 2009 | Singer 7426 Mechanical Sewing Machine
Singer 7426 Mechanical Sewing Machine Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
