Question about Fisher and Paykel GWL11 Top Load Washer
Tub fell balance rod broken
Tub fell while washing a load. Balance rod broke.
  • 70 Answers
Oh Sweet,
Posted on Aug 01, 2010
Could the spinning barrel be off center,what has come off?
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
Mar 19, 2015 | Washing Machines
Machine goes out of balance & vibrates on spin cycle
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
I have a Samsung washer model number wf338aab/xaa my tub is off balance
Sep 17, 2014 | Samsung WF328AAW Front Load Washer
Why is my basket leaning to the side on my easing machine
Sep 06, 2014 | GE Washing Machines
Always out of balance
out of balance is from the tub not level and or the air dampeners on the ends of the suspension rods are broken( top loader machines ---machine type not stated --
if it is a top loader and you laid it on its side , it is possible that the tub is now not level and the dampeners have been damaged
Oct 23, 2017 | Washing Machines
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
THE TUB IS WOBBLING AROUND INSIDE THE MACHINE.
either the top tubs "balance-ring" is leaking the balance solution and needs replacing or the tub springs are broken or disconnected from the tub
Jan 01, 2011 | GE WJRR4170E Top Load Washer
Kenmore Elite tub shaking badly
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 10, 2009 | Kenmore Elite 45986 Front Load Washer
Wash machine spinning off balance
Jan 01, 2009 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
101 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
