Question about Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator
LIght in bottom freezer will not stay on.
We bought out frig, in January. The light in the bottom freezer went out, and we replaced it. It worked for a few hours, now it will not go on again. It can't possibly need a new bulb already. Any other suggestions about what to do?
docjohn174
  • 943 Answers
SOURCE: frig and freezer warm most of the time
HI thanks for your question, i think what your problem is . the compressor is over heating and cutted out. clean all the coils at the back of the fridge. if theres a fan motor at the back make sure its going check that thanks
Posted on Oct 17, 2008
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Posted on Mar 11, 2009
whytfang
  • 170 Answers
SOURCE: Jenn-air side-by-side: freezer & frig cold on the bottom not top!
It sounds like 1 of 4 things...
1. It could be related to the evaporator becoming Iced over and when this happens it insulates the area iced over and the temp rises...this is caused from the defrost cycle not being activated...(Thermostat, or loose or broken wire)
2. There is a device called the thermistor which senses temp and Ice build up which will cause the unit to go into defrost...this could be bad.
3. The previous fixes may cost a little but not as much as the next which could be a restriction in the evaporator. This is serious and usually requires the replacement of the same...very pricey. Is there only 2 compartment or a pull out drawer for freezer foods..If so you could have an isolated problem in the upper freezer compartment which may be remedied without great cost
If your husband or yourself ..or a handy person can access the back of the freezer by removing the back panel I'm sure you will find either lots of Ice good..as far as cost to repair goes....or no Ice...bad...bad.. as far as cost to repair..the later falls in line with a restriction.
I hope I have helped....please rate me ...The Fang
Posted on Mar 27, 2009
SOURCE: Frig warms up Freezer warks fine. Defrost temporarily solves problem.
The defrost heater is burned out.
Posted on Apr 26, 2009
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Sub zero model 700tc problem. frig heated up to 86 degrees. freezer is fine. What do I do?
Hello.
Well moondoggie, it sounds like your light is staying on. You can depress the light switch while the door is open to confirm this. If it doesn't go out, you need a new switch.
Give it a try and let me know.
fil
Mar 06, 2011 | Sub-Zero 700TC Bottom Freezer Refrigerator
Will not dispense ice or water, beeps when lever is pushed, no interior light in frig part. both frig and freezer work, freezer light works
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFI2569VE Bottom Freezer French...
Frig LED settings and bulb do not work
u might have unpluged something
Feb 13, 2010 | Refrigerators
Our kenmore refrigerator/freezer went warm. We
It could be one of several problems -
1) Failed compressor relay
2) Failed compressor
3) Failed component in the defrost system
4) Bad door gaskets
5) Failed door light switch
Questions to answer -
1) Was the compressor (large black domed item with three tubes (one stubbed) at the bottom back of the frig.) warm or hot?
2) Was the condenser fan running?
3) Was there thick ice buildup inside the louvers of the back wall of the freezer?
4) Was the fan running inside the freezer?
5) Look up my "Tips and Tricks" article on testing your door gaskets.
6) Open the door slightly and look inside as best you can. Is the light on or off? Continue to open the door until you see the light go on to confirm the light switch is working.
Your response will give us an idea where to look to find the problem.
Dec 13, 2009 | Cars & Trucks
Need cubic feet for a 1962 Fridgidaire Frig with a bottom freezer
It took a while but I went online to a website that has old newspapers. I looked for an ad in January 1962 newspapers. The model # is FP1-13B-62. The frig came in 13.3 cu ft with a bottom freezer that held 152 lbs.
Nov 29, 2009 | Frigidaire Refrigerators
Freezer Works Frig Stays at 70
Wow, pay for the Premium Assistance Plan to get a quick solution ! I fixed my issue but thanks for the help ! I went to a FREE online forum and got my fix.
Mar 25, 2009 | Maytag MFD2561HE Stainless Steel Bottom...
Water collects on shelves and below the crisper bins at bottom
Mar 11, 2009 | Refrigerators
Fridge freezer not working but lights on
Our new 10 day old top frig/bottom freezer stopped freezing, then the top refrigerator stopped cooling, but the light was working and you could hear some motor running and an occasional "clicking" sound. One internet blogger adsvised unpluging the appliance for 1/2 hour. Another advised 2 hours. Then plug in the appliance and see if it started cooling/freezing again. Our experience = nothing. We called the repair folk and the new frig/freezer had a failed compressor and a broken timer!! We were not thrilled. Suprisingly the store we bought the ap[pliance from gave us a $50 gift card to compensate for the lost food. They didn't have to do that - so ask for it; can't hurt.
Aug 03, 2008 | Refrigerators
Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator Logo
18 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
