We can hear the tv but get no picture with cable or DVD player
  • 108 Answers
Probably the tv is not receiving video signals, check for video/hdmi cable for cut or loose contact of cables.
Posted on Jul 29, 2010
  • Lauren Martin Dec 05, 2010
    Same issue only with Direct TV, we have tried all cords and switching the other HDMI cable from our other TV that works just fine. sound and no picture and it worked just fine for over 48hrs=(
  • Vivek Sant Dec 06, 2010
    If you are able to see the picture with other sources that means your TV is absolutely fine, if the issue is only with Direct TV, you need to confirm that the receiver you use for the Direct TV is working fine by connecting it to another TV set, Most of the LCD/LED Tv's require a minimum signal of 480P/576P or whatever it is, if your Direct TV receiver is not capable of supporting the min signal it will simply switch off the display unit being out of sync, You can try tuning the progressive scan and also try setting the refresh rate to some lower value.
The DVD will go in but the picture is black and yo can hear but the picture out
Usually DVD players have audio and picture "out" connections to go to your TV. Verify that your cables are connected. If it has worked in the past and suddenly started, disconnect then reconnect the cables at both the DVD player and TV end. Cables do not usually go bad but unfortunately DVD players are considered disposable and are not usually repaired any more. If you have multiple video/audio connections on the back of your TV (like Video 1 & Video 2) switch the cables from one to the other. Be sure to keep your cable sets together and don't do something like video output to video 1 and audio output to audio 2. If that works for you then you may have connectors on the back of your TV going out. Hope this helps you.
Nov 07, 2017 | Televison & Video
Could hear the chanels good but no pictuere
Hello
1. Check the video connection of any devices plugged into the television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
2. Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
3. Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
4. Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
5. After all the steps and it does not come on then you would need to visit a technician.
BEST OF LUCK
Dec 15, 2010 | RCA TruFlat 27F520T 27" TV
No sound or picture from dvd
And you have selected the HDMI2 input in the TV menu? If yes, try the dvd on another TV, if you have one. Also try reversing the HDMI cable.
Jul 01, 2010 | Bush DVD2038 DVD Player
When i connect my dvd player to TV i only hear sound but no picture
hi there
your dvd player got three cable one red two white
three yellow ok here i go dvd player input plug in the yellow cable in the yellow in put @ the back of your dvd dvd player
the white cable and red cable is your sound the yellow cabe is your picture see that you have a yellow input @ the back of you tv and plug in the yellow in it then it will work
Dec 14, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
No picture on tv when playing dvd or videos
I had the same problem, no sound. Just a picture. Check the cables you have running from the VCR to the TV. They may be plugged to the TV incorrectly.
Mar 25, 2009 | Sony SLV-D380P DVD Player/VCR
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Jul 08, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
No picture, but can hear sound
hold down the stop button for 5 sec on your dvd player not the one on the remote control
Check your connections. Make sure they are hooked up correctly(ie yellow to yellow. Check both the connectoins on the dvd player and the tv.
Feb 11, 2008 | Cyberhome CH-DVD 300 DVD Player
Connecting DVD player to TV
I'm not sure how much you know about the cables, I know I don't know anything about the specific TV and DVD player you have, but if the chords are AV cables (most likely) then they're most likely color coded, but not all TV connectors are. The audio part of the cables are white, and the video part of the cables are yellow. Other than that the only suggestion I have is making sure the TV is on an "imput", "video", or "game" channel (it's not one of the normal channels, and just about every TV has a different name for it). I don't know if any of that helps, so let me know, and if there is anything else I can do to help, I will. Also, sorry if any of my information is confusing.
Dec 30, 2007 | Disney PC1310 TVD TV
Dvd player
Hi, where you plug the dvd cables into the tv determines where the picture will be seen; Example, if you plug the dvd players yellow, red & white cable into the tv`s "input 1" then you go to the tv`s "input" or "tv/video" button and push those buttons to get "input 1" to come up on the screen and you`ll see the picture and hear the audio, it`s kinda like a file folder in your computer, you`ve got to find the file then open it to see the contents. If your tv is on channel 3 or 5 or whatever you won`t see the picture because the picture is in video not a tv channel
BMW Rider
Dec 12, 2007 | RCA F20352SF TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
