Question about Refrigerators
Maytag Refrigerator Model MZD2766GEB ice maker is barely making ice I replaced the thremostat and heating element two weeks ago can you help me fix it?
  • waynehuff Aug 02, 2010
    why does the freezer fan in a top freezer Maytag not work. We placed is when it was about 4 years old, now it does not work again afer 15 months.
    Also the ice maker does not dumpout the icecubes
  • Refrigerators Master
  • 3,083 Answers
This can be a convoluted problem, unfortunately, and there are excellent blogs that help you attack it, and figure it out. A defrost timer, bad fan, or control board can be bad, or you can be low on freon. Here is a discussion of the problem, and things to check:
http://applianceguru.com/forum1/1558.html
If you suspect something related to your problem, like iced coils, etc., you can find many articles to explain what to check.
This condition can also be due to stuck flappers. Start defrosting the coils, then figure out why they failed to defrost (control board), etc.
Good luck, and hope this helps.
Posted on Jul 29, 2010
The ice cube maker heating element doesn't seem to work very well. Many time ice has stuck in the unit and i need a blow dryer to get it to release it. I need to do this almost once a week
Corry unfortunately about the only and best way to fix that is to replace the ice maker itself the parts are expensive if you like but it's just not worth it to rebuild it that's my opinion ice maker click here=> http://www.repairclinic.com/PartDetail/Ice-Maker-Assembly/D7824706Q/915772?replacedManufacturerPartNumber=61005508?RCAID=35836 Ice Maker Assembly D7824706Q
Aug 30, 2016 | Maytag MSD2734GE Side by Side Refrigerator
My maytag refrigerator crushed ice will not switch back to cubes
Try replacing the ice bucket. That has the teeth and gears that crush the ice up. It could be stuck. If not then there's a solenoid in the back of the freezer that switches the ice bucket from cubed to crushed. You'll see the rod in the ice bucket slides into a square hole that moves up and down. That's it there.
Aug 25, 2016 | Maytag Refrigerators
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
My Maytag Plus refrigerator was stored for 3 years in a climate controlled storage. I moved it a couple of weeks ago and ran it for a week or so without hooking up the water line, and it was working great....
If that is the model number above your post let me know or if different. Most times the dual water control valve sticks or or may need to replace. Place water in the trays and if it freezes cycles and dumps the ice maker is OK but the ice maker during is last few seconds of cycle tells the valve to open. Try that first and I will find you a service manual and part numbers. Sea Breeze
Dec 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker stopped making ice. I had to melt ice
Jim, you will need to replace the heating element and most likely once this has been replaced, your ice maker should work properly unless the ice broke another part on your ice maker.
I would start with the heating element first.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number and we will get the correct part out to you asap!
We look forward to getting your ice maker working properly again soon!
Thanks, Ella
Nov 09, 2009 | GE Profile Arctica Stainless Steel Top...
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Ice Maker Problem Question
take the ice bin out look in the hole at the ice maker you may have a ice cube stuck between the tines of the ice maker if not look at tines somtimes they get crossed up if not that feel in the ice maker does it have water or ice in the maker? also there is a on off switch on the side of the ice maker make sure it is on, you will also see the white ice level arm you can move it up and down it is about 8 in long make sure it is free to move
May 22, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker isn't making ice...
check the white plastic lever inside the ice box. it needs to be in the down position to make ice and is probably stuck.
Mar 05, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
NOT ENOUGH WATER.
Check to see if the water line is kinked or if the valve is partly closed.next check to see if you have some blockage in the line. Shut the water off, remove the filter element,if you hace one and blow air in the water dispenser. If that doesn't do it, remove the line after the shut off, and blow air in before the filter. if all is good you may have to replace the water valve solenoid. Is your ice maker making ice ? if not it is not getting water either. let me know if this helps..
Sep 09, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
