Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
DEFROST PROBLEM WHY DOES THE FREZER FREEZE UP? DEFROST HEATER AND THERMOSTAT AND MAIN CONTROL BOARD HAVE BEEN REPLACED.
    President:
  • 1,891 Answers
You said a mouth full . any of the 3 would cause freeze up.. so make sure the inside fan (evap fan is working ) . if unit is newer one the control in side fresh food may be bad and the sensor in the freezer. if it does not sense tempt properly the compressor run time is too long causing freeze up . now some times new components fail so ck them . . clean the bottom coils . and make sure the bottom fan is cooling the coils .. mm
Posted on Jul 29, 2010
Where is the defrost timer located
Usually in the inside back of the frezer, could be a dial on the fron you just shut it off and let it defrost. Some people unplug.
May 19, 2015 | Refrigerators
I have a GE Profile refrigerator model #PFSSPKXBSS and the front control panel gets frozen. The only time I can change the settings is when the display panel goes haywire and starts changing all the...
solenoid for the ice dispenser flopper might get rusted, so the flop door would not close and freezer air would escape building up ice. need new solenoid assy for ice dispenser door and possible flopper.
Mar 27, 2015 | GE Refrigerators
Fixya manuals
It doesn't defrost
  1. Defrost control board
If the defrost function is not working on your refrigerator it could be an issue with the defrost control board. This control board oversees several internal conditions and regulates the activation of the defrost cycle. A faulty board can be the primary reason your refrigeration unit is not transitioning to the defrost cycle. Over time, the buildup of ice on the evaporator coil will prevent the refrigerator and freezer from maintaining proper internal temperature. It is advisable to first check the defrost heater and the defrost thermostat for continuity prior to replacing the defrost control board.
  1. Main control board
A possible cause for a refrigerator not defrosting, especially on more modern units, is the main control board. The main control board acts as a "brain" for the unit controlling the defrost cycle, compressor, and run time, and essentially acts in place of the defrost timer. The control board can be tested using an ohm meter for functionality and will need to be replaced if bad.
  1. Defrost timer
If the refrigerator is not defrosting the timer could be malfunctioning. Numerous times throughout the day the defrost timer should cycle the defrost heater on as a means to melt frost buildup on the evaporator coils in the freezer. If this timer does not cycle on, then it may be faulty and require replacement.
  1. Defrost heater assembly
If your refrigerator is not defrosting accurately this could be an indication that your defrost heater assembly has failed. This could cause the frost to accrue on the evaporator coils, eventually blocking the airflow resulting in the unit not cooling properly. The defrost heater assembly can be monitored for continuity using an ohm meter and will need to replaced if there is none present.
  1. Defrost thermostat
Another cause of your refrigerator not defrosting is a faulty defrost thermostat. A requirement for the defrost heater to activate to melt away frost on the evaporator coils is a functional defrost thermostat. The defrost thermostat senses the temperature of the evaporator coils and initiates the thawing process by activating the defrost heater. If the thermostat is faulty, it will not sense the lowering temperature of the coils and will not turn on the heater, resulting in an advanced frost build-up. The defrost thermostat can be checked for continuity by using an ohm meter; if there is no continuity the damaged part will need to be replaced.
  1. Defrost sensor with fuse
Another possible cause of a refrigerator that does not defrost properly is a defrost sensor with a fuse. If the defrost sensor fails, the fuse acts as a one-time-only fail safe for the sensor -- if the sensor does not shut off the defrost heater, the fuse will blow when the set temperature is reached. This safety precaution is to keep excessive harm from your unit by the heater and is a one-time use, resulting in the replacement of the entire defrost sensor.
Defrost drain problems
  1. Clogged or freezing defrost drain
If you are experiencing defrost drain issues, it is possibly due to a clogged or freezing drain that is blocking water flow to the bottom of the freezer. This will cause the defrost water to drain and drip down to the bottom of the freezer section. To correct this issue, thaw any ice or remove debris that could be causing the clogged drain or replace the drain heater.
  1. Drain heater
If you are experiencing defrost drain problems, inspect the defrost drain heater. A dislocated or burnt out drain heater will result in the drain tube freezing over. Attempt to return the part to the designated position or replace the damaged part to correct the issue. Search Over 2 1 Million Appliance Parts
Sep 06, 2014 | GE Monogram ZIRS36NM 36'' Stainless All...
Ice forming on bottom of freezer compartment Samsung RF4287HARS.
dont worry about it, you probably didnt get the freezer drawer closed all the way. frost will form when it doesnt get closed properly. just make sure it is closed now and the unit will clear the frost in a few days thru normal defrosting cycles. be sure that the drawer is closing on all sides by looking at the gasket and all should be ok in the future.
Nov 02, 2013 | Samsung RF4287HARS French Door...
Neff integrated fridge freezer
test this steps and fix it, use the VOM. God bless you
  1. Defrost control boardIf the defrost function is not working on your refrigerator it could be an issue with the defrost control board. This control board oversees several internal conditions and regulates the activation of the defrost cycle. A faulty board can be the primary reason your refrigeration unit is not transitioning to the defrost cycle. Over time, the buildup of ice on the evaporator coil will prevent the refrigerator and freezer from maintaining proper internal temperature. It is advisable to first check the defrost heater and the defrost thermostat for continuity prior to replacing the defrost control board.
  2. Main control boardA possible cause for a refrigerator not defrosting, especially on more modern units, is the main control board. The main control board acts as a "brain" for the unit controlling the defrost cycle, compressor, and run time, and essentially acts in place of the defrost timer. The control board can be tested using an ohm meter for functionality and will need to be replaced if bad.
  3. Defrost timerIf the refrigerator is not defrosting the timer could be malfunctioning. Numerous times throughout the day the defrost timer should cycle the defrost heater on as a means to melt frost buildup on the evaporator coils in the freezer. If this timer does not cycle on, then it may be faulty and require replacement.
  4. Defrost heater assemblyIf your refrigerator is not defrosting accurately this could be an indication that your defrost heater assembly has failed. This could cause the frost to accrue on the evaporator coils, eventually blocking the airflow resulting in the unit not cooling properly. The defrost heater assembly can be monitored for continuity using an ohm meter and will need to replaced if there is none present.
  5. Defrost thermostatAnother cause of your refrigerator not defrosting is a faulty defrost thermostat. A requirement for the defrost heater to activate to melt away frost on the evaporator coils is a functional defrost thermostat. The defrost thermostat senses the temperature of the evaporator coils and initiates the thawing process by activating the defrost heater. If the thermostat is faulty, it will not sense the lowering temperature of the coils and will not turn on the heater, resulting in an advanced frost build-up. The defrost thermostat can be checked for continuity by using an ohm meter; if there is no continuity the damaged part will need to be replaced.
  6. Defrost sensor with fuseAnother possible cause of a refrigerator that does not defrost properly is a defrost sensor with a fuse. If the defrost sensor fails, the fuse acts as a one-time-only fail safe for the sensor -- if the sensor does not shut off the defrost heater, the fuse will blow when the set temperature is reached. This safety precaution is to keep excessive harm from your unit by the heater and is a one-time use, resulting in the replacement of the entire defrost sensor.
Read more: http://www.appliancepartspros.com/repair-help/refrigerator-repair-help.html#9#ixzz2aX5nUL00
Jul 30, 2013 | Refrigerators
Freezer coils freeze up solid with ice and have to be defrosted manually
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | GE Refrigerators
Kenmore Fridge, freezer compartment is cold according to thermometer, but ice wont freeze & frozen foods thawing out, weird. Fridge part is about 65 degrees. What could it be?
Should be around 10 degrees.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 30, 2009 | Refrigerators
Ge frig does not freeze on freezer side
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Model rs21dcsv freeze is working but fridge is not working
CHeck to see if there is ice built up on the back wall of the freezer. If so you have a defrost problem. Manually defrost it then take the back wall out of the frezer and check ohms on the heater if heater is ok then replace just the defrost timer and thermostat. If heater is bad replace all three.
Nov 18, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
80 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
