Question about Zebra Eltron P520 High Speed Printer/Laminator (P/N P520C-E000U-ADO)
GBC 5270 laminator not working
Need manual & schematic for GBC 5270 laminator
(not Zebra Eltron P520 High Speed Printer/Laminator ... need this to post)
Gbc does not make this machine any more and refusews to service or advise (thank you very much!)
laminator not working: heat elements disconnected (OK with that: want to cold laminate) ... has this disrupted circuit?
just need motorized rollers & rheostat to work.
machine is 230volt 1 Phase (spec plate) motor is 180 volt ... can I wire the motor directly or is there some sort of voltage level control on the motherboard that saves the motor from overloading?
It is presently wired to a dedicated circuit: square D 20 amp dual breaker (with one throw: bottom) white wire to top pole, gray to bottom pole , ground to ground bar.
2 Suggested Answers
fxurikfx
  • 20 Answers
SOURCE: problem with zebra p420i
The Zebra P420 does not come with a lamination module, are you trying to reset the counter on the P520? Or are you referring to the card counter on the P420, if you are referring to the printer card counter, it can't be reset, it's for manufacturer to know the usage of the printer if they need to service it. (It act like millage on your car)
Posted on Feb 10, 2012
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
GBC Ultima 65 laminator rolls very fast on lowest speed setting and doesn't roll at all on fastest speed setting. Can this be fixed?
sounds like the yellow and the orange wire connectors on the main board from the transformer are reversed. If not, then your main board needs replaced. I have them available, 405-324-6092, Scott,
Westco Laminating service
Feb 24, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle27 Laminator has no control board power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......Westco Laminating Service 405-324-6092.
Jan 08, 2014 | GENERAL BINDING CORPORATION Laminating...
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
Problem with zebra p420i
Go in to control panel,
Printers. RT Click On p210i,
Properties, Device Settings Tools.
Send this Command using the Direct Commant
input Box. Just the First line..
1 +LC 0
Not This--
0
= Counter Value
Dec 16, 2008 | Zebra P210i Thermal Printer
Error message
Issue related stuck due to objects such as paper or plastic. make sure its clean and gears are moving.
Good luck
Jun 17, 2008 | Zebra Eltron P520 High Speed...
Zebra Eltron P520 High Speed Printer/Laminator (P/N P520C-E000U-ADO) Logo
457 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
