Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
My printer mfc 440 brother not recognizes new cartridge installed not brand name
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the printer head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
___
Posted on Jul 29, 2010
Brother printer won't recognize ink cartridge.
I use generic cartridges all the time in my brother printers with no problem. better to pay $2 per cartridge than whatever the brother brand ones cost!
Jan 03, 2010 | Brother Multi-Function Center MFC-240C...
Brother MFC 490 is not recognizing off brand ink
try to remove the cartridge and put it back again after a while
Sep 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
BROTHER MFC 440
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother MultiFunction Center MFC-440CN...
Mfc 440 cn brother printer does not recognize the cartridge
This is crazy.... It is probably a faulty cartridge, ink jet unit stopped up, or a cable that could be loose in the machine from the main board to the cartridge unit. There is a possiblility that the board could be bad too... This units are made so cheap so that you will buy them and then they charge you alot of money for the ink cartridges. You get disgusted with it and buy another one and that is how they make their money. It is just a revolving cycle all the time with Brother, HP, Canon, Okidata, and Lexmark too...
Dec 03, 2008 | Brother MFC-440CN InkJet Printer
Replaced ink cartridge printer continues to say no cartridge
you need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Nov 08, 2008 | Brother MFC-440CN InkJet Printer
Not recognizing cartridge
myprinter tells me"noblack ink," they are both b it is brand new cartridge why?this is the second black ink cartridge i have bought it says the same thing.i always buy "BROTHER"
Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc 7820n toner cartridge issue
Look at the left side of the cartridge next to the blue release button. There should be a white tab in an arc slot. If the white tab is anywhere but all the way to the right, it does not recognize the cartridge. Try truning the drum and pushing the white tab down to the right, it shoudl reset it and find the cartridge.
Jan 15, 2008 | Brother MFC-7820N Laser Printer
Mfc brother printer
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Sep 13, 2007 | Brother MFC 420CN All-In-One InkJet...
Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Sep 03, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
