The three lights on the printer. The first one will not quit blinking, so I can print anything. I tried shutting everything down, but it's still blinking.
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the printer head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
___
Posted on Jul 29, 2010
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Sep 19, 2014 | Brother HL Office Equipment & Supplies
Zebra 105SL The printer was printing labels just fine on Friday. Monday morning it won't print anything. I send a document to it for printing and it just sits there doing nothing. Everything is connected...
Go to "Printers and Faxes" or "Devices and Printers" and try printing a test page by right clicking on the icon and choosing printer properties. This will better define if the problem is something wrong with the printer or connection OR if it is a software issue.
Oct 11, 2010 | Zebra 105SL Thermal Label Printer
My computer doesn't send picture to be printed to my hp photosmart 8450. I have Windows Vista and it worked before. Now why does it show an error in the printer info and also, this printer is set as...
If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
Sep 21, 2010 | Dell Office Equipment & Supplies
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
The printer won't print anything and the on/off light blinks
you can unplug it for a long period of time and plug it back in and try it. Also, try using a can of compressed air to blow out any debris. Also, check HP's site under you model to make sure you can replace one cartridge without replacing the other.
Otherwise you may have a mechanical issue the would require professional repair, I think that model is about 6 years old and you would probably be better of buying new.
Jul 18, 2009 | MicroBoards PF-2 InkJet Printer
Printer won't print. amber light blinking.
try to power off printer remove the AC adapter, and hold down power button for 30 seconds, then plug in AC Adapter and power on, that may "Reset" the printer. You may be having an intermittent hardware failure. Let me know if this doesnt work. Thanks for any votes
Mar 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Cartridge light blinks.
Try printing a testpage to see if the problem is w/ the printer, press print + cancel
Nov 11, 2008 | Kodak EASYSHARE 300 Photo Printer
HP deskjet f340 all in one printer
hi this is problem with Cartridge please cheak with Ok cartridge it should be working
if this information is useful for u pls rate me .........
thankyou....
Jun 09, 2008 | HP PSC 2210 All-In-One InkJet Printer
55 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
