Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
If there is an electricity failure how can we have a hot shower
    Novelist:
  • 120 Answers
Easy answer is you cant on these units. These tankless units store no hot water and need a 240V power supply to operate.
However!
In some areas in far north Queensland I came up with a back up power unit (I used to work for Rinnai who make similar units). These were for remote units that used battery lighting and just wanted a bit of hot water for remote workers.
Basically you need a spare car batttery and an electrical inverter or a back up petrol generator. These hot water units only use a very small amount of electrical power even when that are operating. I had a guy run the hot water for nearly two weeks on a car battery and inverter after cycone Larry hit Innisfail in North Queensland.
Depends how often you get power losses as to how much money you want to spend to cover yourself (99.9999% don't bother with no real hassles).
Posted on Aug 01, 2010
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 05, 2013 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 25, 2012 | Rheem Water Heaters
I have to turn the hot water tap on full open to get hot water
Type of water heater is unknown
If you have single-handled faucet the faucet cartridge might be bad.
If you have recirculation system, then check valve might be bad.
Copy following links for troubleshoot.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Jul 16, 2012 | Water Heaters
Is my hot water heater going out??
if its electric check your lower element
Mar 13, 2012 | Water Heaters
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
Hot water not lasting enough for a shower hot water not lasting for shower or doing dishes,
one of your elements is out...fairly ez to replace.. should have to little access panels on front..more than likely its the top one thats out but consider replacing both..
Nov 21, 2010 | RELIANCE ELECTRIC WATER HEATER
Hi, I just got my new DHC 10-2 today, the installation was easy but I have a problem. The problem is that heating is not constant. Once I mix the cold and hot water I should have an uniform temperature but...
This electric demand water heaters has one heater element. The flow switch turns it on. The thermostat cycles it on and off according to temperature. There is no medium.
You need to run the sink on hot while you take a shower. This kind of cancels out the savings on electricity.
Or get a higher flow shower head. Your screen on the shower head may be partially fouled.
Here is the brochure. It shows the flow rates for the different models.
http://www.stiebel-eltron-usa.com/sites/default/files/pdf/brochure-dhc.pdf
Dec 14, 2017 | Stiebel Eltron DHC 10-2 Electric Tankless...
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
80 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
