Question about KitchenAid KGRS807S Gas Kitchen Range
My Kitchen Aid Gas Range Architect Series II is showing an error message of F6E0 Lost Communications. How do I fix this issue??
  • dmfakas Jul 29, 2010
    Dont know if it helped yet as i Just shut off the power to the range. I hope it works. Thanks
    Brigadier General:
  • 4,090 Answers
The problem is with the time keeping unit. You will need to reset the unit. Unplug it for 30 minutes then plug it back in. If that does not work then check for bad ground wires that are not fully grounded on the unit. If you find a problem and need to order the part you can order it at repairclinic.com
Note some times it cannot be turned off so to Interrupt the power to the display turn off the power for 30 minutes via the switchboard power to the house as it may be hard wired. That should reset the error.
Thanks for using FIXYA
Posted on Jul 29, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Will not turn on
Hi
Your kitchen aid hood is not turning on due to a blown fuse or a faulty slide switch. Please check part#21 (Thermal fuse)---
Part#5 is the Sliding switch, if fuse is fine then replace this switch. Hope this helps... Please post back if you need more information. Daniel
Feb 27, 2011 | KitchenAid Architect II KHTU705S Stainless...
I have a kitchen add KGSS907 it is showing an error message F6E0 lost communications how do I correct this
F6 E0 means the switch pulse return line to the electronic control is not connected
The usual way to correct this is to replace the electronic control (clock).
You might want to check for loose or burnt out wires on the clock unit before replacing tho'.
Dec 17, 2010 | KitchenAid Architect Series KEBC107KSS...
Kitchen Aid Gas Range Architect Series II-self cleaned the oven; it is done the oven is cold but the door is locked and nothing works on the control panel.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | KitchenAid Kitchen Ranges
Lost communications error code F6E0
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control.
Sep 10, 2010 | KitchenAid KESS908SPS Electric Kitchen...
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | KitchenAid Architect Series KEMC308KSS...
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Kitchen Aid gas range error code "F6E4 lost communications"; oven not turning on
i had some milk boil over and got this error message on our oven. we had a tech come out and he said that we would have to replace a control board for $280. he went away to order the part and in the mean time i had to shut off power to some circuits and when i turned the power to the over back on it worked fine. i would try this before replacing the part
May 22, 2009 | KitchenAid Kitchen Ranges
KitchenAid KGRS807S Gas Kitchen Range Logo
83 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
