Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Ao error message in Hayward heaters
My spa heater is showing ao error message and would not kick in to start heating help
  • 760 Answers
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Posted on Jul 29, 2010
  • dpmjt Jun 25, 2011
    Had same problem when starting pool heater for first time after winter. Found that mice chewed through the vacuum gray hose/tubing that runs from the motor to a diaphragm-like thing at the inside top of the heater. Easy fix, bought tubing and clamps at hardware store for $5.00. Heater works now and no error code.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
This forum is fantastic! I tried to fire up my spa yesterday for the first time in months, and got the AO code. I'm sure the answers I found here saved me well over $100. I took off the front panel, and immediately saw the severed vacuum hose. Luckily, it had been gnawed through in such a way that the longer piece could be used by itself, so $0 repair cost. I wrapped the hose in foil and duct tape, in hopes of discouraging another critter attack.
ao error message in Hayward heaters - ao-error-message-in-hayward-heaters-5fbqss5mlsyd4xzsh5wyryce-2-0.jpg
Posted on Feb 24, 2015
My spa is showing an OHH message. What is causing this message?
Make and model would help. How about my best guess?
OHH means OverHeated Heater caused by an error
One of the Water Temp Sensors has detected 118°F (47.8°C) In the Heater and Spa Functions are Disabled. You Must Press Any Button to Reset when Water is below 108°F (42.2°C). Check for Water Level, Flow Restrictions, Closed Valves, Air Bubbles, and Pump Prime, or Continue for a Detailed Test Procedure.
WARNING:
A Heater Overheat Error Message may indicate Excessively High Heater Temperatures which can Scald or Burn!
If the Heater is Not Cool Enough to Safely Service, allow the Heater to Cool before Continuing Testing.
A Heater Overheat Condition that generates an "OHH" Error Message is Most Likely the result of a Low Flow Condition. Therefore, "OHH" is considered to be a Flow Related Error.
Check for All of the following Conditions:
1.Low Water Level.
2.Blocked Suction Fitting.
3.Blocked Skimmer.
4.Dirty Filter.
5.Too Many Closed Jets.
6.Closed Slice Valve.
7.Heat Related Pump Not Running.
8.Heat Related Pump Not Primed.
9.Contact your Dealer or Service Organization.
DO NOT remove the protective covers from any electrical enclosure, or attempt to service any related electrical device, unless you are a qualified electrician or service professional.
As a responsible adult, always check the topside control panel display for errors and verify safe water temperature before using a spa, and before allowing children to use a spa. Safety should ALWAYS be your first consideration
Nov 15, 2015 | Pool & Spa
Hayward h400 pool heater blower not starting
it could be a bad blower vac switch, and you may look at the rubber tubing going into the switch to ensure it hasnt dry rotted.
Apr 07, 2014 | Hayward H Series Pool & Spa Heater 400k...
Hayward HP error
check voltage coming in if ok check voltage after transformer if ok check safety circuit pressure switch voltage both leads if not replace or check for plugged copper line
May 04, 2012 | Hayward Heat - Pro 2100 Heat Pump Pool...
Brand new just installed with gas hooked up ao error message tube okay and blower working - ao message after about 1 minute after turning on
I recommendyou call the Hayward technical support at 908-355-7995and they might be able to help you figure this issue out. Ihope this helps.
Sep 17, 2011 | Hayward H Series Pool & Spa Heater 400k...
The tube or hose that connects my hayward spa part # IDXLBWR1930 is broken. I am getting an AO error.
This tube connects between the blower and a vacuum or pressure switch. If the tube is broken the switch can't detect whether the blower is working. If you fix the tube then the system will continue its sequence and if it finds no more faults it should ignite and the heater can heat.
Aug 06, 2011 | Hayward series Heater Combustion Blower...
Hayward Heater Problem ''AO'' error. H400IDH
Thank you for posting your question here on Fixya.com.
It sounds as if the air activated switch the tube you mention attaches to is not working. Pull the two wires from it and connect them to simulate the switch closing. Start up the heater to see if you get ignition. If so, replace the switch.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Feb 14, 2010 | Hayward H Series Pool & Spa Heater 400k...
Blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
2,275 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
