Question about Phase Linear UDV9010 Car DVD Player
The spring on my phase liner came off. Where does it go so I can put it back?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Phase Linear Master
  • 2,226 Answers
There are several springs inside the unit. without taking the deck apart and making a visual inspection it is impossible to say where it may have come from.
Posted on Jul 29, 2010
Why tub liner comes off every time I load & unload?
Do you mean front boot assembly? If so, there is a band with a spring on it. that needs to be put back in place. You should call a service tech to have it put back on.
Jul 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Kitchenaid Hobart K45SS when set at 1-2 accelerates to high speed when making dough. How can I fix this?
Usually when the mixer runs only on high speed it is caused by the control plate adjusted incorrectly or the control plate spring unhooked. Remove the trim & end cover on the mixer and check the control plate spring, if unhooked, attach to bottom of the control plate and squeeze the spring end, also check the speed control plate screws,there are 3 screws on this plate, one at the bottom two at the top, see if adjusting the top screws slows your mixer down.
Next check the wiring of the mixer, Insure everything is wired correctly, to get wiring diagram go to the last page of the service manual. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
If neither of those fixes the problem it is probably a bad phase control board, or a shorted phase control board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run, if it operates at full speed the phase control is defective and needs to be replaced.
Use the service manual to aid you in taking apart the mixer, trouble shooting the problem and putting the mixer back together, based on the mixer only running at high speed some of the time I would assume it is the speed control phase board.
If you have any questions let me know.
Thank you,
Colleen
Customer Service
MendingShed.com
Apr 24, 2013 | KitchenAid Food Mixers
How to change alternator belt for 2003 cavalier
Hello wndsmth,
Drive BeltReplacement Removal Procedure 1. Raise andsupport the vehicle. Refer to Vehicle Lifting. 2. Remove thefront fender liner. 3. Rotate thedrive belt tensioner counter-clockwise to release the spring tension. 4. Remove thedrive belt. InstallationProcedure 1. Rotate thedrive belt tensioner counter-clockwise to release the spring tension. 2. Install thedrive belt. 3. Install thefront fender liner. 4. Lower thevehicle. See picturebelow. Regards, netvan
Apr 02, 2011 | Chevrolet Cavalier Cars & Trucks
Drivers side door on 2004 KIA will not unlock. The lock moves slightly and the passengers door unlocks cleanly. I have tried several times and cannot even unlock the door manually.
Took off door post liner, was able to access the screws holding the door liner on, removed the door liner and was able then to open the door. Replaced broken hold back spring on the door lock.
Jan 29, 2010 | Kia Rio Cars & Trucks
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
I have the inner basket out of a Whirlpool LSR5132PQ Top Load Washerand I filled it with water to see water dripping out around the rubber gasket? in the center of the outer plastic liner basket. I'm...
wow ok you have there srprnigs to remove on the right side remove the clip spring by removing the 1/4 in nut driver head screw,,and do the same for the lef side,,,noe you have 1 more spring in the rear,,the counter balance spring this has 2 screws remove them,,now on the right side remove your pressure switch hose...go to the bottom of tub and remove your tub to pump hose..ok nw left hold tub up and twist back and forth and pull at the same time...reverse to put together..onthejob
Feb 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Clamp
I use a needle nose vise grip at the top, make sure not to puncture boot. put it around the left side, then i use small screw driver to hold spring on one side, then pull the other side of spring until it goes over boot. Be carefull not to stretch spring to far.
Oct 22, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Phase Linear UDV9010 Car DVD Player Logo
37 people viewed this question
Top Phase Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
