Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
I have lost my network key, and can not connect to the internet with my new laptop. How do I find the network key or reset the system so that it is not private?
  • 755 Answers
Use a wired connection to the router and get the local IP address for the router. Usually something like 192.168.2.1
You type the routers local address into a browser search window or address bar and you end up on the setup page for the router.
There you can reset the password and make a lot of other changes.
Posted on Jul 29, 2010
Lost net work adapter and Internet connection
get model number and operating system and download network adapter and Wi fi adapter drivers .Then install on p.c.
https://www.asus.com/support/Download/45/7/0/1/POi1J7z06m5LfgvC/41/
Sep 02, 2016 | ASUS Eee Computers & Internet
Acer AspireOne safe mode setup
You are posting a docking station for a laptop. You need to make sure you Network Connections are good before attempting to use the dock with network.
More than likely you simply lost the drivers for the Network Interface Card,
Jun 04, 2013 | Computers & Internet
Did pc system restore and lost internet connectivity to router. can connect thru modem. have wireless internet connectivity on laptop. want to reconnect internet to pc without losing wireless to laptop.
run this on your laptop - it should yield the wireless key necessary to connect to your network again.
http://www.nirsoft.net/utils/wirelesskeyview.zip
Sep 17, 2011 | NetGear WGR614 Wireless Router
Lost password/unknown security key
Connect your laptop to router using ethernet cable open internet explorer & type 192.168.0.1 press enter it will take to login screen and if you havent changed the username and password for the router it should be admin as the username and password as password. once in the router you can change the network key to anything as desired by you.
Jun 04, 2010 | NetGear DG834G Router
Lost signal on acer aspire 6530 lap top, dont know if my daughter has pressed a wrong button or switch ?
There is a little satellite icon next to the always blue (when turned on) skip to next (song) and stop (square) touch buttons. Put your finger on the satellite icon for a few seconds, then move off, a green message should come up on the bottom of your screen saying "Wireless LAN enabled", if it says "Wireless LAN disabled" then there is another problem with your connection.
When the wireless is enabled check that you're connected to the wireless network. Start > Control Panel > Network and Internet > Network and Sharing Center (in Vista) you should be able to see:
"Access Local and Internet"
If it's not connected to the internet try resetting your wireless router, if that doesn't work, check you have the correct network password. Right click the two little PC screens (icon) in the bottom left, in the new window right-click your network and go to properties. In the new window, "Security" tab check the settings and type in the correct network security key (password) again. Hopefully you will have a record fo the network security key or your problem will have already been fixed before you get to this point. :)
Sep 27, 2009 | Acer Aspire 6530-5143 Notebook PC
Desktop works (direct to router), laptops cannot connect
first of all make sure that the wireless settings of the router match the settings of your wireless computer.
make sure also that there are no friewall or security programs running in your computer because they can interfere with the wireless connection as well.
Aug 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
Method to add another laptop to wireless Linksys in home. Model no: WRT546 Serial no. CDFF1G506178 password lost...tried ADMIN
just try reset in your linksys and reinstall once again the driver for it in both your laptop and set a password for it .....
Aug 07, 2008 | Computers & Internet
Changed router settings and now unable to access the network and internet
Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
Jul 28, 2008 | ASUS Computers & Internet
Internect connecting
If the laptop was connecting wirelessly before and you didn't change the wireless security key on the router during your troubleshooting steps with the ISP then it should just reconnect. If it doesn't reconnect you should probably delete the wireless profile that's saved and try connecting again. When you delete the wireless profile you will have to enter the security key again. Make sure you have this information handy.
If you are uncertain what the wireless security key is use your desktop that is physically connected to the router to log into the router and reset the security key.
To log onto the router you need to know the routers IP Address. You can obtain that information through the following:
START MENU
RUN
Type CMD
Click OK
Type IPCONFIG
Hit Enter
Look for the default gateway. The default gateway is the IP Address of the router. By default the IP is 192.168.1.1.
Type whatever IP Address you discovered into the address bar of your web browser (Internet Explorer for most) and hit enter.
You will be prompted for a login. If you didn't change the default login information to the router it should be a blank username and the word: admin - as the password.
Navigate to the wireless settings and reset the security key.
From your laptop key in the new network key.
Hope this helps.
MO
Jul 18, 2008 | Linksys Wireless-G WRT54GS Router...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
276 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Greg Ulan
Chris Larocque
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
