Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JD Model 445 - Plastic gears. After replacing the new camshaft I need to adjust the valves. Does anyone have the specifications?
  • Al Spiegelhalter
    Al Spiegelhalter Aug 03, 2010
    gwhbike, thanks for the info - exactly what I needed.
I have own John Deere 455 as 780 hours. I started the engine on and running as normal, but the battery light stay on, not turn off. I tried to move front or back, nothing move at all. Is something with battery and alt? Let me know. Thanks! Rich
Posted on Apr 01, 2011
Remove the plugs. Turn the engine so the pistion is at top dead center for cylinder. Clearance should 0.010 when adjusting rocker to valve. Repeat for other side. I just replaced my cam shaft if a 1993 JD445. I'm planning to run for a couple of hours then check cleanace again. Hope this helps, Gerry
Posted on Aug 02, 2010
No valve movement on 320 John Deere lawn tractor.
the jd 320 lawn tractor is fitted with a 2 cylinder water cooled vertical shaft Kawasaki engine
parts numbered -j59051 and , I 59051 show it as a gear driven cam shaft
I would be looking for the rocker arm bolts loose /stripped, bent push rods or the key or the key that drives the crank gear has sheared
May 02, 2017 | Cars & Trucks
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
How to adjust valves on my 86 honda xl250r 1986
1986 Honda XL600R How To Adjust The Valves
instructions still valid for a 250 . ring local Honda dealer for clearances
Mar 19, 2014 | 1986 Honda XR 250 R
Need timing marks and how to adjust dual cam gear marks after removing heads
Register for free at autozone.com. List your make, model and so on, you know like so anyone knows what you got!
Repair guides specific to your car, it has timing diagrams and procedures.
Feb 04, 2014 | Cars & Trucks
Check Engine light on 2005 Toyota Echo, Code P0012
Error Code: P0012
Fault Location:
Camshaft Position (CMP), Intake/Left/Front, Bank 1 - Timing Over-Retarded
Possible Cause:
Valve timing.
Mechanical fault.
Camshaft position (CMP) actuator.
Intake Camshaft Adjuster tight/stuck.
Intake Camshaft Adjuster faulty.
Possible Solutions:
Check Intake Camshaft Adjuster.
Check valve timing.
Check the timing gears.
Sep 28, 2012 | 2005 Toyota ECHO
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
John Deere Model 445 garden tractor. Replaced plastic cam shaft gear, tried to start motor and it backfires through carb. I just removed front cover of engine to check the timing marks on both the camshaft...
Hi
Please check for the anti back fire solenoid in the front of the carb. Check whether the wiring to it is fine and if it is getting +12 V. If yes then you maybe required to replace the solenod.
However, if this doesn't resolve the issue then you would need to adjust manually so that decompresser works normally. Inspect the flywheel key as well, it may have sheared.
Check the carb filter and the make sure there is no sign of water in/around the carbeurater. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Aug 04, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 445 tractor v twin 22 hp engine, john deere k series, no compression, removed valve covers and valves not moving, is there a timing chain, gear ?? or what drives the cam? Do you think the cam...
The cam has broken, this is a common problem with the 425/445. The cams are very cheap, made with plastic. Had mine replaced last year at the cost of about $300. Had water pump replaced as well.
Apr 01, 2009 | Garden
2000 escort zx2 part name and how to remove it
would like to help looked on one in yard thats in for repair and their isnt one,(europeon model ).where does the other end go too ?? white tape would have been better if its in the well just to the left of the no 1 spark plug their shouldnt be any oil their only a water jacket beneath it ?? strange one this,,,is their a sort of plastic button on the end peice like the fuel lines if so pull it out and it should come off.Honestly iam at a loss never seen this on a europeon model.
Dec 12, 2008 | 2000 Ford Escort
Bent pushrod on inlet valve,husqvarna rideon mower
it is one of two problems - your engine uses a cam with a plastic gear - this gear has a tendency to move - it will probably need replacement . there is also a chance that the valve seat is coming loose (overhead valve ) which keeps the valve open - check the distance of the valve stems to make sure they are both out the same distance if they are not then when you put a new pushrod in and adjust it the valve will be pushed too far and hit the piston in turn bending the pushrod
Oct 15, 2008 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
435 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
