Question about HP Photosmart C7280 Printer
HO C7280 ink system failure message 0xc18a001
I have the ink system failure message about 3 weeks ago... 0xc18a001 after having my 7280 for about 2 years.
I did a master reset and it was back to normal... for the 1st time. Yesterday, the same message came out again.
Did #*123, change cartridges, shift the small white gear... nothing works. The error message keeps coming up.
I am using compatible ink cartridges... do you think that could be the problem? One thing though... when I remove all the cartridges.... and turn it on... it still showed the error message!
Not sure if I want to go buy HP original cartridges to test it out. If it still fails... then I would be wasting money.
Any ideas? Thanks.
sagarjd
  • 95 Answers
SOURCE: "Wrong Cartridges" Error HP C5180 now Failed ink system.
Please perform the following steps:
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button
Display should say “Support” and display the FW rev (something like R0616R)
Now, perform the following instructions:
1. Press and release the right arrow button until the displaysays “System Configuration Menu” 2. Press and release the “OK” button.3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.5. Display should say “Hardware failure status: Clear. Press OK to clear”.6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. 11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.13. If the error is still there, or reoccurs replace the unit.
Posted on Jul 27, 2008
SOURCE: Ink system failure
I had exactly the same problem with my HP 8230 and tried all the posted sugestions with negative results till I stumbled on this site site offering an update for a different problem but added " also clears many ink system failure messages " I downloaded and installed the update and the printer burst into life and now works perfectly, which proves mine was a software problem not a hardware one. give it a try you might get lucky.
http://www.birseyindir.net/driver/HP_Photosmart_8230__Print___12760.html
Alan
Posted on Jan 05, 2009
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
VKUR
  • 62 Answers
SOURCE: HP 7280 printing super slow Windows XP
There is a document that i have pasted so please check the link .
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01933252&cc=us&lc=en&dlc=en&product=3204785
ALL THE BEST HOPE IT WORKS .........
Posted on Feb 21, 2010
bandana_gyrl
  • 181 Answers
SOURCE: My HP photosmart C5180 has a Ink System Failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It
can be pointing toward a firmware failure in the printer and if that is the case the
following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration
Menu”.
outlet first and then into the back of the printer.
followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK
Good Luck!
As a side note if the printer cannot overcome the error the only printer still sold that takes 02 cartridges is the Photosmart C8180.
Posted on Apr 21, 2010
How do I fix "ink system failure oxc18a0206" message on my HP Photosmart C7280 all-in-one?
Hopefully, this link will take you to the proper troubleshooting page.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03081973&lc=en&product=3204785&tmp_track_link=ot_search#N213
You'll click on the third plus sign on the page (+) because your message DOES include the words "ink system failure."
From there, you'll choose, by looking at the pictures, whether your printer has a removable print head.
You'll click on the appropriate answer -- yes it does, or no it doesn't,
Then, you'll identify which print cartridges your system uses, and THAT will take you to the proper troubleshooting steps for your printer's specific configuration.
The fix may be something you've already tried -- turning off the printer and unplugging it (but did you unplug it from BOTH the unit AND the wall, and then did you wait at least 15 seconds?), or the fix may be to service the printer.
Good luck! :)
Aug 07, 2014 | HP Photosmart C7280 All-in-One Printer
I have error code Oxc18a0001- ink system failure. Can you help
Psil posted a possible solution 29 days ago; I repeat for your information:
just had this exact issue with my C7280. I called HP Tech support, got a body in Bangalore or someplace, and was pleasantly surprised that they were prompt and knowledgeable, and solved the issue very quickly after transferring my call one time to a hardware support expert.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 14, 2011 | HP Photosmart C7280 Printer
I have a printer ?HP c7280 All-in-one?a message, ?Ink system failure, error: 0xc18a0201.?
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
Jan 11, 2010 | HP Photosmart C7280 Printer
HP C 7280 printer states ink jet failure. I have tried resetting machine, resetting the ink cartridges, and holding # 6 down on start up. I have replaced all low ink cartridges.
have your printer head check it is most likely the one causing these problems, if you have already replace it with a new cartridge and have reset the machine then it is likely the problem have it check by a qaulified tech to avoid any more damage to the machine
Nov 21, 2009 | HP Photosmart C7280 Printer
HP 6280 INK SYSTEM FAILURE
Try This :
First check with a new set of orginal HP catridge ; if still it doesn't work then the printer needs to be replaced ; call HP if the printer is in warranty they will do it free of COST ; No. for HP is : 18004746836;
Sep 16, 2009 | HP Photosmart C7280 Printer
Printer says ink system failure after refplacing
We have a step by step repair for this printer on our web site at: www.ccl-la.com/HP.htm
This should get you back printing.
Buddy
Corporate Computer
www.ccl-la.com
Jul 28, 2009 | HP Photosmart C7280 Printer
Error 0xc18a0301
Hello Alina,
Please Click here and follow the instructions to resolve this issue.
Regards
laxman
May 26, 2009 | HP Photosmart C7280 Printer
Ink failure
put ink cartridges in the printer
Jul 20, 2017 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 Printer Logo
234 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
