Question about Alpine Type-R SWR-1222D Car Subwoofer
Alpine typr r 12" subs
Hi i just got my two type r 12's back that got stolen on christmas but i dont have my box or amp but thats not my problem the banana jumper cables that go in the subwoofer are missing and i talked with the guy in the install bay at best buy n he said i could just use regualr speaker wire but i am curious is that ok or should i found out where u can get those cables at and if i do need those cables where can i buy then online or in a store please help me write me back at chicago_king18@yahoo.com thank you
    Champion:
  • 227 Answers
You are ok with regular speaker wires. Goodluck.
Posted on Apr 24, 2008
What box should i use for alpine swr-12d2
What size box does this sub need in a sealed box & a ported box. If you have room use a ported box that fits your subs. Probox & other brands may have the perfect box for them. I would tune the box to 40hz if you like loud tight bass.
Jan 24, 2013 | Alpine 2 Swr-12d2 Car Ausio 12" Dual 2-ohm...
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
How to wire 2 alpine typre r 1242 to an alpine pdx1000 mono amp??
If they are single voice coil, just hook one up to the amp (bridged) like normal and run a jumper wire from the positive of the sub to the positive of the second one, then do the same for the negative....This will give you a lower ohmage, thus better bass!!!
Oct 19, 2010 | Alpine Type-R SWR-1242D Car Subwoofer
I just picked up a 12" type r in a box with a alpine m 350 how do I know what kind of type R I have without taking it out of the box?? and how do i hook it up to this amp??
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Sep 10, 2009 | Alpine SWR-1222D 12" Type-R Series...
I have a set of Alpine Type R 12 inch subs... I have a 1500 watt amp powering them but when I turn the music up, the bass cuts out. Where should I start looking for the problem?
ground is loose(most likely amp), battery running low, subs might be damaged? feel free to keep me in touch if problem occurs more after checking grounds and power source and subs. Also might need to re-tune your head unit and amp?
Jul 03, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
Subwoofer stopped working
Put another known working speaker in there to see if it works. If it does then the issue is with your speaker. If it also does not work your amp is to blame.
Sep 16, 2017 | Alpine SWR-1222D 12" Type-R Series...
How do i run it 2 ohm stable
This is how 2 type r's are wired to one amp at 2ohms hope this helps dont forget to rate me thanks
Upfront Audio :)
Apr 06, 2009 | Alpine MRV-1507 Car Audio Amplifier
System cutting out
Pull the subs out of the box and check the connections... Check to see if the wires running from the connectors on the sub itself to the voice coil... had a JL 10 that had a frayed wire to the voice coil system would cut in and out. Hope its helpful
Mar 30, 2009 | Alpine SWS-1240 Car Speaker
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Alpine Type-R SWR-1222D Car Subwoofer Logo
235 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
