Question about Crown CP660 6-Channel Amplifier
How to hook up a mixing board to a cp 660 crown power amp
    Genius:
  • 1,175 Answers
Go to the Crown website
All the diagrams are there
Posted on Aug 17, 2010
When I turn on my crown xti2002 amp it won't stay on it powers off
It's best to assume there is a short circuit in the power amp board. The unit is going in to protect mode to stop it blowing fuses etc. Could be caused by bad speaker wiring or connections by the way.
Nov 30, 2016 | Crown Audio Players & Recorders
Mixing board hum
AC hum comes from poor grounding of components.
Jun 21, 2017 | Music
I like the sound of my practise amp but it's not powerful enough can i connect it to a larger amp without getting feedback/distortion?
you can use the record outputs to run the signal into a stereo receiver without problems, though it would likely sound better with a shure sm57 microphone hooked up to a mixing board or other instrument amp.
the record output should be PERFECTLY balanced to hook up to a consumer-level stereo reciever with NO distortion; however, this record output might be too loud for another instrument amplifier or a mixing board; hence, the microphone in the latter situation.
short answer- "yes, but..."
Nov 26, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
When iam switching on my canon cp 660 model copier while initillazing it shows error E 196
From the service manual:
The communication between the DC
controller PCB and the reader controller
PCB is faulty.
• The communication between the DC
controller PCB and the PS/PCL
board or between the reader controller
PCB and the PS/PCL board is
faulty.
printer1.blogspot.com/.../canon-cp660-service-manual.html
Service and repair manual at above link.
Aug 01, 2010 | Office Equipment & Supplies
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Hooking up in Stereo
You'll need to use one of the four stereo inputs on the mixer and make sure you wire the speakers separately to channels one and two of the amplifiers. Assuming both of your amps are xti series amps, that's all you have to do.
Good Luck,
BB
May 14, 2009 | Audio Players & Recorders
Finding a way to hook this up
Send main 1 out to your Crown. Jump Mon send to PWR am insert.
Mar 11, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Orion xtr15 to a american leagacy la 660 amp
your only choice is to run the amplifier at a 4 ohm mono load - this will not reult in the amplifier making much power.
Positive on sub to Positive on amp.
Negative on sub to Negative on amp.
This is your only possibility.
Adding a second sub in the same fashion will result in a 2 ohm load, and your amplifier will run at its rated potential.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 05, 2009 | Orion Xtreme XTR15 Car Speaker
Hooking up 2 speakers to 1 speakon output
Power Output (1 kHz*) Stereo Bridge-Mono 8 Ohm 4 Ohm 8 Ohm XLS 802 500W 800W 1600W XLS 602 380W 600W 1200W XLS 402 300W 450W 900W XLS 202 200W 300W 600W *1 kHz Power: refers to maximum average power in watts at 1 kHz with 0.5% THD. It depends on the impedence of the speakers. Carfull as you could burn up this amp if you exceed the resistance rating on it. Go here on all of the specs of this model of crown amps. http://www.crownaudio.com/amp_htm/xlsspec.htm Good Luck
Mar 27, 2007 | Crown XLS202A 2-Channel Amplifier
Crown CP660 6-Channel Amplifier Logo
164 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
