Toshiba Satellite A135 PC Notebook
Problem for Toshiba Satellite A135 PC Notebook
Pioneer dvd-rw dvr-k17a
By gdanielle on Apr 24, 2008
the drive is not recognized by the os, cant run any disc, i have checked in device manager it says;Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
I have a Toshiba A305 S6825 with a Pioneer DVD DVRKD08L ATA DVD player but no disc will work . When i go to device mgr it reads "windows (39) cannot install driver.
Same Problem
May 26, 2009
-   THE SOLUTION DIDN'T WORKS
THERE IS NOT SUCH KEYS OUT THERE!
-   Guest
May 17, 2009
-   Toshiba Satellite L355D-S7825 does not detect the DVD-RW Drive (pioneer DVD-RW DVRKD08L)?? I rebooted and nothing. I checked all over the internet and on toshiba / support nothing listed?-   Guest
Apr 22, 2009
-   can not load the drivers-   Guest
Mar 06, 2009
-   says the file is incomplet or damaged and will not allow me to use my drives-   Guest
Mar 01, 2009
-   same w my new sony vaio laptop -   Guest
Best Solution
posted on May 15, 2008
Very Helpful)
Tmyers12
Rank: Apprentice
Rating: 99%, 24 votes
I have the same problem and found a solution that works beautifully
To resolve this problem, remove the affected filter drivers. To do this, follow these steps: 1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue. 2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM. 3. In the right pane, right-click UpperFilters, and then click Delete. 4. Click Yes to confirm the removal of the UpperFilters registry entry. 5. In the right pane, right-click LowerFilters, and then click Delete. 6. Click Yes to confirm the removal of the LowerFilters registry entry. 7. Exit Registry Editor, and then restart the computer. Note After you remove the UpperFilters registry entry and the LowerFilters registry entry, you may lose functionality in certain programs such as CD recording programs. In this scenario, you must reinstall any affected programs. If the problem recurs, contact the program vendor to determine whether an update is available for the program.
For information about how to contact computer software vendors, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base: 65416 (http://support.microsoft.com/kb/65416/) Hardware and software vendor contact information, A-K
60781 (http://support.microsoft.com/kb/60781/) Hardware and software vendor contact information, L-P
60782 (http://support.microsoft.com/kb/60782/) Hardware and software vendor contact information, Q-Z
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #2
Very Helpful)
charlaooo
Rank: Apprentice
Rating: 98%, 28 votes
i found the solution at microsoft support website, but i just found in portuguese, so im gonna try to explain how to solve it.
u need to go to start menu and then on the star search u need to search for "regedit"
when u are inside the regedit, look for this subkey "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
on the right side u need to del 2 subkeys
"upperfilters" and "lowerfilters"
close the regedit and restart the windows.
hope i can help u guys. it worked for me.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #3
posted on Apr 30, 2008
Very Helpful)
konjeeva
Rank: Apprentice
Rating: 98%, 7 votes
I have a Pioneer DVD DVRKD08L ATA DVD playe
Was this helpful?
Yes
No
Solution #4
posted on Jun 04, 2008
Helpful)
billymac4568
Rank: Apprentice
Rating: 92%, 2 votes
The solution is as TMYERS12 states and is not that hard. My Toshiba laptop had the same problem and was under warranty so I rang Curry's. They knew about the problem and suggested I delete the registry keys. It's caused by downloading additional software - mine was caused by ITUNES adding additional code to VISTA!!!
Was this helpful?
Yes
No
Solution #5
posted on Nov 19, 2008
Somewhat Helpful)
donyablo
Rank: Apprentice
Rating: 75%, 1 votes
Was this helpful?
Yes
No
Solution #6
posted on Jan 03, 2009
Not Rated)
mbarakauny
Rank: Apprentice
Rating: 0%, 0 votes
Hello! I have a laptop Toshiba Satellite A135-s4427, Same thing happen the way u describe, Windows failed to load drivers and I was about to burn a dvd when it happen like that, I surf net to look for solution but they didnt work, i dnt know about registy, I then got a solution, of course the last solution one can possibly take :), I backed up my important files to a media drive, Put my Recovery Discs and made an out-of-box recovery of my Laptop... Its Worked for me!!!
Was this helpful?
Yes
No
Solution #7
posted on Nov 15, 2008
Not Rated)
ashkanblue
Rank: Apprentice
Rating: 0%, 0 votes
Just go to regedit and find this sub root " HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318 " and delete the upper and lower filters, just be aware that if you use the registry optimization software then this problem will result again and you have to do the same thing again , good luck
Was this helpful?
Yes
No
Solution #8
posted on Nov 11, 2008
Not Rated)
medbouj2001
Rank: Apprentice
Rating: 0%, 0 votes
i have a toshiba laptop model satellite P200-13F and a few days ago i've had the same problem , so please i'd like to resolve it as soon as posible .
Many thanks
Was this helpful?
Yes
No
Solution #9
posted on Aug 16, 2008
Not Rated)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
Thank you so much, i could solve my problem as well!!!
Popular Solutions for Toshiba Satellite A135 PC
Questions and Unsolved Problems for Toshiba Satellite A135 PC
Do you recommend Toshiba Satellite A135 PC Notebook?
Answer
Answer
Gma 4082 n device driver DVD player not working Code 10. dvd doesn't even show in my computer
Answer
My Toshiba Satellite L40 18Z WIFI Driver wont work!!!
Answer
volume wont work at all on my laptop it wont even let me adjust it what do i do?
Answer
You gave a solution to go to run and follow steps but when i try an error message pops up and says... (More)
29 Other Users Have The Same Problem - Continued
Comment by mistabatu, posted on Feb 24, 2009
Hello! I have a laptop Toshiba Satellite A305-S6862, Same thing happens to me, it actually shows my dvd-rw driver but when i insert any kind of cd it does not show up, either autorun or when i try manually  to run cd. i followed all the instructions which we have been told above but it did not work out at all.I surfed on the net to look for solution but i could not find anything helpful. i would like to recieve any kind of help over here
thanks in advance
Comment by Guest, posted on Feb 19, 2009
ME TOO WHAT DO I DO TO FIX THE PROBLEM
Comment by yazidtim, posted on Feb 16, 2009
PIONEER DVDRW DVRKD08L ATA DEVICE
Comment by MGorgeski, posted on Jan 23, 2009
I have the same problem and there is no driver available for download, at least I cannot locate in 2-3 days intensive search
Comment by Guest, posted on Dec 25, 2008
How do you fix???
Comment by Guest, posted on Dec 11, 2008
thenksssssssssssssssssssssssss
Comment by forjul, posted on Oct 28, 2008
Comment by Guest, posted on Sep 07, 2008
Six months ago I bought a Toshiba Satellite A205 and it was full of problems. Unfortunately I couldnt afford to be without a computer for several weeks while they ineptly tried to figure out what the problem was so(for some reason when I click on anything an unrelated window will pop up) I put up with it until today.
Today I went out and bought a brand new Toshiba Satellite 305 so I could finally put the other one in the shop. Everything seemed great until I got ready to start loading programs. Thats when I discovered that the D:/ wasn't there! And when I looked in the hardware section of the Control Panel I eventually saw the same error message everyone else here saw. How funny that the replacement computer is in worse shape than the one it was supposed to replace! What are the chances that something is wrong with EVERYONE of Toshiba's Satellite systems?
I can honestly say I have bought my last Toshiba product! Fool me once shame on you....fool me over and over again then I deserve it!
Comment by ramacap, posted on Sep 04, 2008
Comment by israni303, posted on Aug 25, 2008
i have toshiba satellite L45-S7409 laotop my dvd is not working i updated windows but its not woking i have vista
Comment by abs24021990, posted on Aug 19, 2008
i have a sony waio and my system does not recognise any disc inserted in the cd rom. the device manager says this device cannot start(code 10).
Comment by cjluvz, posted on Aug 18, 2008
I have a Toshiba A305-S6859 and I had the same error code (code 39). The player will not funtion.
Comment by TPCarving, posted on Jul 23, 2008
my Poinerr DVR-RW DVR-K17A ATA Device will not play or work with any cd or DVD either. I am also having problems with backing up file to it so I am a little worried about my Norton protection.
Comment by csatennis, posted on Jul 15, 2008
This device cannot start. (Code 10) DVR-K17A ATA
toshiba Satellite A135-S4427
Comment by Guest, posted on Jun 30, 2008
Same problem exists with Satellite A305 Notebook!
Comment by Guest, posted on Jun 04, 2008
I had the same problem with my Toshiba Satellite A215 with the same Pioneer DVD-RW DVR-K17F ATA drive installed. As mentioned by one of the others, my problem was also instigated by installing iTunes, and deleting the upper and lower limit registries worked beautifully. Thanks!
Comment by ashkanblue, posted on May 29, 2008
I bought the Toshiba A305-56825 four days a go and suddenly the DVD Drive stoped working. I tryed all the features of windows to fix the problem but nothing worked, thanks to this recommendation. It worked great and the DVD Drive is working back again. thanks
Comment by Guest, posted on May 28, 2008
Great solution, worked like a charm.
Comment by curtisf, posted on May 18, 2008
This recommended fix was spot on. Followed it 100% and the result was great. THANKS
Toshiba Satellite L355-S7812
Comment by Guest, posted on Apr 30, 2008
I have sam problem
Comment by Bran123, posted on Apr 30, 2008
I have a Satellite A305 series and it's giving me the same problem! A its NEW!
Comment by Guest, posted on Apr 28, 2008
Just bought today new Toshiba L350 and have exact same error !.
Comment by Guest, posted on Apr 27, 2008
I just bought this 3 days ago and I have the same problem. This sux big time...somebody please find a solution!!!!
Comment by Guest, posted on Apr 26, 2008
i have thesame problem
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(646) 202-3935
Macbook LCD Screen Replacement $159 iPhone 3g...
NYCiPodDoctor 877-TUNEDOC (8863362)
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
